It is currently Sat Oct 24, 2026 9:44 am
 Post subject: Timing Issue
PostPosted: Mon May 01, 2023 12:47 pm
Tying to adjust the timing on my 170 slant six; pretty straight forward, but.. the distributor hold down bolt (slot) only allows for limited movement., I need to turn my distributor a little more clockwise., but I can't. Anyone else have this problem??
 Post subject: Re: Timing Issue
PostPosted: Mon May 01, 2023 1:15 pm
The distributor plates like yours actually have two slots. One you can readily see and the other is reached from the underside of the distributor.
PostPosted: Mon May 01, 2023 2:54 pm
You need to get the special wrench or take the dist. out to access the 2nd adjustment screw.
I have also set the dist. in one tooth off to give me more adjustment on the top side slot sometimes too!
Users browsing this forum: Amazon [Bot] and 6 guests
