It is currently Fri Jan 02, 2026 1:46 am
 Post subject: fischer balancer
PostPosted: Sat Aug 07, 2004 5:36 pm
anyone know about them,quality e.t.c.
there is only one...
PostPosted: Sat Aug 07, 2004 7:57 pm
Mike Jeffrey has used a Fisher balancer for years on his race car. He loves it. :shock:
PostPosted: Sat Aug 07, 2004 8:05 pm
Just a heads up. I am currently bidding on this item. Planning on using it on my new engine, if I win.
PostPosted: Sun Aug 08, 2004 8:08 am
The one I have works well, I did have to trim the mounting hub shorter to get the unit to come up close to the timing chain cover so I could run pulleys.
Setting-up your pulley system is always a "challenge" with the aftermarket dampeners seeing that the Slant has the belt running real close to the front of the engine.
A while back someone fron Fisher put a post on this message board saying that they had a new p/n which solved the belt alignment issues, try a search or contact Fisher at http://www.fisherconcepts.com/
 Post subject: Wrong link
PostPosted: Sun Aug 08, 2004 7:59 pm
Sorry Doc,
I couldn't get the link to go to them??
Rick
PostPosted: Tue Aug 10, 2004 9:46 pm
have run mine fot years
Will
