It is currently Tue Sep 29, 2026 8:40 pm
 Post subject: I need a Carburetor
PostPosted: Sat May 20, 2023 4:48 am
I'm at my wits end trying to get a well functioning carb for my 63 Valiant; My original Holley 1920 has been "rebuilt" bu friend but it still runs like crap; So I bought a "new" remanfuctured Carb from Rockauto (an "autoline" 1 bbl carb, which I think is a UnRemco carter) It also runs terrible in spite of all my adjustment efforts. SO,,, I am tempted to send my Holley off to (Uremco) to have it rebuilt.... Is this is a wise move?? I am not sure where to go from here..
 Post subject: Re: I need a Carburetor
PostPosted: Sat May 20, 2023 5:50 am
Car Model: 1966 Dodge Dart
Might need to be more specific on what sort of crap it's running like.
While I can easily believe a parts store carburetor would be junk out of the box, this could potentially be a totally different issue such as an ignition problem.
Matt Cramer
PostPosted: Sat May 20, 2023 11:03 am
I've tuned the motor (new plugs, new wires, new distributor, adjusted the timing (when it did run), also new reconditioned head, including new springs, etc.
Plus it idled fine, just bogs down really bad when I open the throttle.
PostPosted: Sun May 21, 2023 7:18 am
Sounds like a vacuum leak, have you put a gage on it to see what your reading?
PostPosted: Mon May 22, 2023 3:52 am
Yeah, not a vacuum leak
PostPosted: Mon May 22, 2023 4:28 am
If it idled fine, probably not a vacuum leak. Sounds like either a timing issue, or bad accelerator pump shot. Did you check that the timing mark on the damper is actually at TDC? What is the timing set for, with the vacuum advance disconnected, and at what RPM?
PostPosted: Tue May 23, 2023 5:18 am
Timing is good.. Bad accel pump sounds like a possibility, I just have to figure out how to determine that.... thank you
PostPosted: Tue May 23, 2023 6:39 am
Timing is good..
"Timing is good", means nothing. what is "good"? 0 degrees, 5, 10, 15 ? Factory specked some slant sixes at 0 degrees, I have one slant that is at 15 degrees, and another about 10. But I do lean toward the accelerator pump.
PostPosted: Tue May 23, 2023 11:27 am
Well I re=checked my timing and it is set a couple of degrees past "0 (My damper marks are only in 5 degrees increments); The shop manual says it should be 2 1/2 degrees BEFORE TDC: So I'm going to reset it andcheck again. Thanks
PostPosted: Tue May 23, 2023 11:53 am
I would try setting it at about 5 degrees before TDC. as a starting point.
PostPosted: Tue May 23, 2023 7:26 pm
Look down the carb and press the throttle down. Do you see a nice long squirt of fuel shoot into the carb? If not the accelerator pump is not working
As Charlie said go to a minimum 5 degrees before on your timing.
When was the last time the valves were adjusted.
PostPosted: Wed May 24, 2023 5:27 am
Do this with the engine off. You might need your eyebrows. :lol: :lol:
PostPosted: Wed May 24, 2023 5:53 pm
How do you know that Charlie! :D :D
PostPosted: Wed May 24, 2023 7:17 pm
I won't tell. :wink: :wink:
