It is currently Sat Oct 24, 2026 12:05 am
PostPosted: Fri Jun 09, 2023 9:48 am
I am thinking about upgrading the cam in my slant six build and was hoping to get your input on the best one for my build as follows:
1984 Dodge D100 Truck Build - Going for reliability, smooth running, good torque (250 ft-lbs), decent horse power (180 ft-lbs).
Trans is A833 4 Speed
Motor = 1986 Slant Six 225 with a previous rebuild .040 pistons. Not sure if block has been shaves 0.10 - will measure soon.
Head = Stock 1986 Head with plans for minor port matching and cleaning up. Not planning to upsize valves. Will upsize springs with cam kit.
Intake = Aussie speed mid length with Weber 38/38 Carb.
Exhaust = Dutra Duals or similar.
Ignition = HEI Mod
I would like the motor to have performance similar to a stock Jeep 4.0 with good pulling power with the 4 speed. I am not looking for a drag racing motor.
In my past builds, I have not upgraded the cam, so this is new territory for me. From the posts I have read on the site, I was thinking a mild RV cam
but was hoping that you that have more knowledge than me can help me find the right cam for my application.
Thanks!
PostPosted: Fri Jun 09, 2023 2:40 pm
What rear gears are in the truck?
Even with stock valves I would clean up the bowl under the seats. And you may want to plane the head some more to bump the compression a bit more. That will help with power and gas mileage. Of course check the measurements for sure.
PostPosted: Fri Jun 09, 2023 5:11 pm
The stock '81-up hydraulic-lifter cam is a wimpy thing. Most of the aftermarket cams, by whatever description ("High Energy", "RV", "Torquer", etc) are ancient generic (often Chevrolet) grinds applied to a Slant-6 cam blank. There are a lot fewer options in cams for the hydraulic-lifter setup. You might want to give some thought to converting to the pre-'81 solid-lifter arrangement instead. You'd have to do a valve adjustment from time to time, but you'd have a lot more and better cam options readily available. If you were to do that, the Dutra RV-15RDP from Oregon Cam would go well with your intake setup. The RV-10RDP would be a little milder—smoother idle, etc—but still a nice improvement over the stock '71-'80 solid-lifter cam, and an even bigger improvement over the '81-up hydro cam.
PostPosted: Sun Jun 11, 2023 6:49 am
Car Model: Slant Six M37
Does anyone regrind cams for the .904 lifter size? Did the Direct Connection/Mopar aftermarket cams utilize the advantages of the "faster" ramps that the .904 lifter would tolerate?
PostPosted: Sun Jun 11, 2023 7:46 am
Hughes Engines says they have mopar cam lobe profiles that are designed to work with the .904 diameter lifter
https://hughesengines.com/
see their Tech article section
On the topic of picking a cam for low rpm torque, that is the route that I took for the slant in the 83 D150.
the article linked is from that project
https://www.slantsix.org/forum/viewtopi ... 19&t=43301
and while we are talking cams, a few of my recommendations.
1) spend the $75.00 and get a copy of Dyno Sim / Desktop dyno
You can run simulations with different cam profiles, lifts, advance - retard settings and see what those changes do for torque and HP curves.
The better your inputs are for: compression, carb CFM, head flow, ignition timing the closer your Dyno Sim output will match reality.
I had the 83 D150 on a chassis dyno years ago and the torque- HP curves were right on line with what Dyno Sim had predicted.
http://www.proracingsim.com/dynosim6.htm
available through Summitt and other retailers
2) in a truck application, I would stay with hydraulic lifters. The valve cover and the rocker arms are a lot further away in a D series that thay are in an A body.
3) I would not count out a 'stock' 81 and up hydraulic cam if low RPM torque is the only goal. Do a Dyno Sim simulation with the stock cam and you will see a lot of torque way down the RPM chart. Ultimate HP is limited as the engine just runs out of air above 3000 RPM, but its worth a look if low RPM Torque is the only goal.
And here is an article with good basic camshaft information.
https://www.motortrend.com/how-to/under ... afts-work/
Regards
DT
PostPosted: Sun Jun 11, 2023 8:38 am
Lots of good ideas/experience/opinions here.
The first thing I would do is decide on the static compression ratio you want, and build the engine for that, then decide on the cam. For pump 87 octane, I would go for 8.5 - 8.8:1 static CR. For 91-93 octane premium gas, I would go for 9.3 - 9.6:1.
For your application, I would suggest staying with a hydraulic cam and we can design a custom cam from Oregon that will use hydraulic lobe profiles.
Users browsing this forum: Google [Bot] and 14 guests
