It is currently Sun Nov 15, 2026 2:23 pm
 Post subject: 85 D100 Driveshaft Loops
PostPosted: Thu Jun 22, 2023 7:26 am
Car Model: 85 Dodge D100
I just thought I would ask if anyone has any experience, tips, suggestions, etc. for installing driveshaft loops on an 85 D100. In the event I break something again, I would rather not have to replace my driveshaft again. Does anyone have a brand or style of loop that they already know works well on a truck like this? I figured I may as well ask before I start ordering things.
Thanks in advance,
Andrew
PostPosted: Thu Jun 22, 2023 12:00 pm
The truck has so much space under there I bet any of the bolt in units can be fabricated to work.
Just because you have a driveshaft loop installed does not mean that parts will be magically saved in the event of a driveshaft or other drivetrain failure. It is a safety measure more than a parts preservation measure.
PostPosted: Fri Jun 23, 2023 12:24 pm
Thanks Greg. I know its not a sure thing, but I figured it can't hurt to have one or 2 under there. While I was under there putting it back together I did look around and it seemed like it wouldn't be too hard to make something work. I guess most people are usually doing this on cars rather than trucks. There was a universal type one on the Speedway site that looked like it might be a good starting point.
PostPosted: Fri Jun 23, 2023 12:37 pm
It's probably no more work to build one from scratch than it would be to adapt something. I made on for the Slant powered S10. It doubles as a frame stiffener.
--> The Diesel Corvette <--
PostPosted: Fri Jun 23, 2023 2:04 pm
Those universal ones show up at swaps too.
Rick can swindle a seller out of one for $0.05 when he was asking $0.25.. :D
PostPosted: Fri Jun 23, 2023 5:23 pm
It took me a lot of years to hone that skill set! :D
PostPosted: Fri Jun 23, 2023 5:54 pm
Nothing wrong with that! I like it!... That means you get more $$ for important bespoke slant 6 parts!
