It is currently Thu Jun 18, 2026 1:55 am
PostPosted: Fri Aug 06, 2004 7:54 am
I'm posting a fresh draft of my Slant Six Electronic Ignition conversion article for your reading pleasure. I used PDF format so I could include pictures and it's Mac compatible.
http://www.potentialtech.com/pmoran/Lea ... -04-04.pdf
Please offer comments and suggestions so it can be useful to others. There is lots more information and pictures I'd like to add, but my time is short, and I think it's alread pretty helpful as-is. A wiring diagram may be the biggest missing piece, but I'll work on that soon and they are available elsewhere.
Thanks for looking.
1980 Aspen 225 super six
PostPosted: Fri Aug 06, 2004 11:40 am
The article looks good, I will send you a few comment "off board".
Take a look at this wiring image, I'm not sure where it came from but it shows the ECU and the added wires.
Should we add a copy of this article to the articles section here at www.slantsix.org?
http://www.slantsix.org/articles/elect_ ... iagram.jpg
 Post subject: Not Quite Finished
PostPosted: Fri Aug 06, 2004 12:27 pm
Yes, I'd like to share the info with everyone, but I'm not sure it's ready. Give me a week to make additions and corrections.
That wiring diagram is perfect! I'll be sure to include it.
email me at :
pmoran -at- paiservices.net
If anyone has comments or suggestions.
 Post subject: Looking better
PostPosted: Fri Aug 06, 2004 1:10 pm
I made a couple more changes and added the wiring diagram. The pictures are much clearer than before. 8)
Some of the info is of questionable value/ correctness, but I think it gets the job done. The best way to learn what you don't know is to try and teach someone else. :oops:
I'd also like to include a few pics of clean installs and factory mounting locations. Many lean burn cars/trucks have the factory mounting holes for clean upgrades. I don't know if older models had them? Take a look!
Now no one has any excuse to run points or lean burn. :wink:
PostPosted: Sat Aug 07, 2004 10:51 am
Sounds like a pretty useful explanation of the Lean Burn system. If you've got a Lean Burn distributor lying around, I could use one for my Megasquirt setup.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
 Post subject: Please post me!
PostPosted: Tue Aug 10, 2004 8:28 am
This is ready. I'll still make improvements, but I haven't recieved anything of interest.
I think it's a good overview for a beginner. It could have saved me several weeks of fumbling with my truck.
For my next trick, I've got patterns for the super six kickdown! They should be ready by weeks end. I'll post them FREE! Athough the parts won't work with most of the stock pieces, it may allow for routing around headers!
 Post subject: Part Numbers
PostPosted: Mon Aug 30, 2004 9:49 am
The wire for going from a module to the dist is $20.DCC-3690152
at your local Mopar dealer,or you can get it from Year one,
summitracing.,etc. :wink:
http://store.summitracing.com/default.a ... cc3690152+
Hey Doc, I'd like to see this added. How goes the HTML version of this article?
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
