It is currently Thu Jul 16, 2026 5:00 pm
 Post subject: Camshaft retainers
PostPosted: Sat Jun 03, 2023 9:07 am
For those guys who build their own engines, what sort of clearance figures have you come up with between the cam bolt and the timing cover. On the engines I have on hand, I have measured about 0.25 inches of clearance. I am working on a cam button for the slant, a trim to fit (for clearance), that basically fits over the cam bolt. I was going to just make it 1/2 inch "tall" but the engineers have told me that this will cause some issues related to shrinkage and thick parts. I/2" would have left plenty of room to trim for clearance, but now I am thinking I might just go with something like 0.35 - 0.40" height.
Any data you guys can offer here would help.
 Post subject: Re: Camshaft retainers
PostPosted: Sat Jun 03, 2023 9:36 am
I run a rocker bolt through timing cover. Honestly the timing cover is pretty flimsy for that but I run mine in until I see the timing cover flex. Then back it off a 1/4 turn or so. I figure that is just a "smidge of clearance and whatever interference may be there will soon wear into place. Always use a smooth head bolt on the cam.
PostPosted: Sat Jun 03, 2023 10:47 am
I am very familiar with that style of cam stop. I have this idea and I will see it through, even if it doesn't work that well.
What's the worst that can happen.,......
PostPosted: Sat Jun 03, 2023 10:57 am
Set your cam up and make sure it's all the way back in the block. Put a lump of clay on the bolt and cover with plastic wrap. Install cover with the gasket, then carefully remove cover. Slice clay and measure thickness.
PostPosted: Sat Jun 03, 2023 1:01 pm
Yes, that is how I measure the clearance. I am wondering what clearances OTHER people have measured. I am in the design stages of the cam button and it would help to have as much data as I can get.
PostPosted: Sat Jun 03, 2023 2:17 pm
Not many do it that way. Nut and rocker adjuster is much easier.
Team Green may have done a spacer at one time.
PostPosted: Wed Jun 07, 2023 12:54 pm
Car Model: 64 Valiant
The timing cover will deform in the area where the button contacts it. You'll need to reinforce it by spot welding a piece of sheetmetal on to the outside of the cover. A cam button from a GM(Buick 231) is spring loaded and can be another option....
PostPosted: Sun Jun 18, 2023 3:02 pm
When I tear the engine down this winter I will let you know what is going on.
I ran that style of button in my 11 second 440 for a few years.
No problems.
Oh yea, a gentleman who won Indy in a Hemi Funny car in 1969 gave me the button.
Pretty sure he knew what he was doing.
PostPosted: Sun Jun 18, 2023 5:06 pm
Well, just an FYI. I have these in the development stage.
Cone shaped ‘button’ that fits over a 7/16” hex bolt head (5/8” wrench)
It is Derlin, roughly 0.644" total height leaving it about 0.400" above the cam bolt head (the cone part).
It fits snugly over a factory slant six cam bolt (pictured). I put a piece of paper inside the bottom just to give contrast for the picture.
PostPosted: Tue Jun 27, 2023 9:28 am
That looks nice Matt. I like it.
PostPosted: Tue Jun 27, 2023 10:40 am
They are very nice.
PostPosted: Sat Sep 23, 2023 8:35 am
Have these made it to the "For Sale" stage yet?
PostPosted: Sat Sep 23, 2023 11:35 am
Yes, they are now for sale in my eBay store, $21.65 shipped.
https://www.ebay.com/itm/334940928290
