It is currently Mon Nov 16, 2026 12:06 am
 Post subject: 4 speed linkage
PostPosted: Wed Oct 04, 2023 6:53 am
Has anyone on here fabricated your own linkages using rod ends? I’m thinking about making my own but I don’t want to reinvent the wheel. Or does anyone have a set of A body overdrive linkages.
 Post subject: Re: 4 speed linkage
PostPosted: Wed Oct 04, 2023 7:41 am
Hey Rick, I was going to do that, but smaller rod ends are a little hard to find the right tubing.
S&W might have what you need.
PostPosted: Wed Oct 04, 2023 8:53 am
It's probably better / more accurate to make your own as most of the factory rods can be quite worn.
I bet you can get a new or nicely reconditioned set from brewer's.
I try to tighten up the rods on my cars but they are wallered out and the nubs are too small and the holes are too big going on 50+ years old now.
PostPosted: Mon Oct 16, 2023 6:03 pm
Car Model: 66 Valiant, 82 D150, 94 Ram 2500 TCD, 69 Dart
I have a set of 833OD shift rods that are going on my 66 when the time comes. If you need photos/measurements shoot me a PM. I can't get photos to post here no matter how hard I try...
PostPosted: Tue Oct 17, 2023 3:51 am
Thanks, I decided just to make the one long rod that was not in too good of shape. I just have to weld an end on and get a shoulder bolt and I should be good. Eventually I will make a set of rod with rod ends on it, but this will get me going for now.
PostPosted: Tue Oct 17, 2023 6:46 am
You might find some at a swap meet also.
PostPosted: Tue Oct 17, 2023 7:49 am
Actually I feel like I can build a better piece than the stamped factory pieces. Time will tell shortly. :D :D
