It is currently Sat Oct 24, 2026 4:33 pm
PostPosted: Mon Oct 16, 2023 7:25 pm
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
1. When the timing marks are lined up on the cam gear and crank gear the valves on #1 cylinder are not fully closed. Engine was rebuilt at a reputable shop.
2. When the timing mark on the crank pulley is lined up with the tab on the timing cover, it's not the same as the marks on the gears AND the valves on #1 cylinder are not closed. The damper seems to be in one piece.
What should I pay attention to here? I am inclined to go with TDC when both valves are closed.
Thanks for your help,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Mon Oct 16, 2023 8:44 pm
Cam is timed to Cylinder #6.
PostPosted: Mon Oct 16, 2023 9:26 pm
Thanks Slantzilla! I had no idea. Any idea why?
Joe
Joe Hoppe
PostPosted: Tue Oct 17, 2023 6:21 am
Car Model: 66 Valiant, 82 D150, 94 Ram 2500 TCD, 69 Dart
It does sound like your cam is timed 180 degrees out - something you need to fix. It should be timed to #1 not #6. Ask me how I know! :shock: :shock: :shock:
If it was done at a shop and returning it is in the cards, that's the easy way to fix this. Make them do it right. If you do it yourself first find TDC on #1 using a piston stop. Then check the timing mark on the damper - it should be dead on. If the damper slipped it won't show TDC correctly, so if needed mark the damper with the new TDC location. Then DEGREE IN the cam. Don't just line it up dot-to-dot.
PostPosted: Tue Oct 17, 2023 8:13 am
Joe
I do not know. It seems silly to have to time it on 6, then make sure it's TDC on 1 to put in the distributor.
PostPosted: Tue Oct 17, 2023 8:42 am
Remember the crank has to spin 2x for all 4 cycles to happen. Spin the crank 1 full revolution and it'll be set for #1 instead of #6.
PostPosted: Tue Oct 17, 2023 9:44 am
Thanks, Don.
Joe Hoppe
PostPosted: Tue Oct 17, 2023 11:26 am
When the timing marks on the crank sprocket and cam sprocket are lined up, # 1 piston is in the cam split overlap position, and # 6 is TDC compression (both valves closed). When the crank is in this position, the distributer must be installed/set with the rotor pointing at #6 terminal on the cap.
If you time for # 1 piston at TDC compression, the cam and crank sprocket dots will both be at the top (12 o'clock ) position. And the distributer should be set for #1 terminal on the cap.
PS: The damper timing mark should be at zero with #1 and #6 at TDC. If not, there is a possibility of:
#1, damper has slipped
#2, wrong timing cover/tab/mark
#3, wrong year damper
PostPosted: Tue Oct 17, 2023 12:20 pm
As Charlie said, all you have to do is use #6 dist/rotor orientation to do the ignition timing, and nothing else has to change. You will still use the timing light on the same timing tab and slot on the damper, once you make this tiny change. I would not bother pulling it or returning it to the shop, but technically I suppose they migh fix it for free. Don't count on that...
PostPosted: Tue Oct 17, 2023 12:29 pm
I don't see anything wrong. Don't worry about the marks on the timing sprockets. They are correct.
Bring #1 piston up to TDC with both valves closed (compression). Install the distributer with the rotor pointing to #1 on the cap. Start it up.
PostPosted: Wed Oct 18, 2023 9:24 am
Thanks, Charlie and Lou. What you are saying makes sense. I will use #1 TDC for setting timing just to make things easier.
Joe
Joe Hoppe
