It is currently Fri Jun 19, 2026 5:17 am
Post new topic  Reply to topic  [ 1209 posts ]  Go to page Previous 146 47 48 49 5081 Next
PostPosted: Mon Oct 30, 2023 3:52 pm
Hopefully you have an O2 sensor on board now? If not Your still guessing at your mixture no matter what carbs you have on it. I hate to see you go to all the work of swapping the Webers since I know how well they work, but if ain't performing you may have to. Keep at it! :D :D
PostPosted: Mon Oct 30, 2023 4:46 pm
I suppose this is all part of the teething process in sorting a car.
Ruster Ran 19.20 the first time out. Then after an engine build, it was solidly into the 13's, then the 12's then the 11's.. Simplify then add lightness. :D
I still have all kinds of problems with the megasquirt on the ignition, but when it works it works well, and I have only myself to blame.
Keep focused, you'll get there. I would also throw that other intake on and see if there is and induction problem or not.
That first engine build sounds like it was a serious engine.
It's hard for me to add lightness to my Colt. About the only thing I can do is go on a diet.
PostPosted: Mon Oct 30, 2023 5:14 pm
Oh not you zilla, I was talking about other folks.
I was talking to Patrick Saturday. That motor always used water and snotted up under the valve cover really bad. I never got any water in the pan. It's possible the head was already cracked anyway.
We're going to try and fix it ourselves. What have we got to lose? :mrgreen:
Jay. Bee. Weld!
PostPosted: Mon Oct 30, 2023 7:47 pm
Pretty sure Patrick is going to TIG it.
PostPosted: Tue Oct 31, 2023 8:03 am
No O2 sensor.
I was reading that they need a certain length of pipe to function correctly.
My fitting, in one collector only, only has maybe 5 inches of pipe to the atmosphere.
I am not going to change carbs till I get the trans/bearing issue resolved and get some good runs done.
PostPosted: Tue Oct 31, 2023 5:31 pm
Mine is only in one header as well and I have about 12" of pipe downstream. You could always hook up a temporary extension on your collector until you get it close.
PostPosted: Tue Oct 31, 2023 6:09 pm
5" is plenty long.
I have less than that on the O2 to the end of the turndown on ruster.
It's not accurate at say Idle but above 2000 it's trusty as a subaru justy! :D
PostPosted: Wed Nov 01, 2023 5:00 pm
Ok, maybe on the O2.
Took the Colt apart today.
Maybe .010 clearance on the bearing.
They call for .100 minimum.
So out comes the trans.
I need some velcro.
PostPosted: Wed Nov 01, 2023 5:43 pm
I've got a 904 with a brake and a 4000 stall you can stick in there. :mrgreen:
PostPosted: Wed Nov 01, 2023 6:07 pm
Won't fit.
The block plate attaches to the mid mount.
But thanks for offering!
PostPosted: Fri Nov 03, 2023 2:40 pm
Trans is out.
Makes a couple of weird sounds as you rotate it from the front.
More to investigate.
Bled the master cylinder on the clutch.
Seems to be working properly.
And I do have the clearance that I had when I set up the bearing the first time.
Around .125, they say .150 is optimum.
Master cylinder was keeping it from pushing back with my hand.
Learning a lot about what isn't the problem.
PostPosted: Wed Nov 08, 2023 1:51 pm
Clutch pedal was sticking and air in the lines.
Trans was on inside.
I put it back together and ran it in the driveway.
Here is the Video:
https://youtu.be/iQo0n3VTIJs
PostPosted: Wed Nov 08, 2023 3:57 pm
PostPosted: Wed Nov 08, 2023 6:40 pm
ok
I need to proofread.
PostPosted: Wed Nov 08, 2023 7:00 pm
Is that trans clutchless Stan?
You got any more chances to test this year?
