It is currently Mon Nov 16, 2026 10:01 am
PostPosted: Sat Dec 23, 2023 12:15 pm
Car Model: 1966 Dodge Dart
So I was able to source another cluster for my '66 Dart - the bad news is the plastic rivet that holds the spring bracket in place has disintegrated. The spring bracket spins freely and the needle bent. I can straighten the needle, but is it possible to source a replacement plastic rivet and fix this myself?
Matt Cramer
PostPosted: Sat Dec 23, 2023 12:47 pm
Probably not, and the speedo is surely due for a new bearing, too.
PostPosted: Sat Dec 23, 2023 12:59 pm
Thanks for the recommendation, just trying to find a way to the "good+cheap" side of that triangle instead of the "good+easy" option of sending it to a rebuilder.
Matt Cramer
PostPosted: Wed Dec 27, 2023 7:54 am
In case anyone is following along: I have found that this rivet thing is called an "upper jewel", but I have not found anyone willing to sell them on their own! But I have found a speedometer that should be in better shape.
Matt Cramer
