It is currently Thu May 28, 2026 9:16 am
Post new topic  Reply to topic  [ 1209 posts ]  Go to page Previous 151 52 53 54 5581 Next
PostPosted: Tue Jan 16, 2024 1:28 pm
Matt
There is a void on the crank right where that booger is on the Damper.
I guess it moved metal from one surface to the other.
It's not pretty.
PostPosted: Tue Jan 16, 2024 1:40 pm
I always Loctite my cam bolt and also use an air impact on them for tigntening purposes. Sometimes they can be not completely centered or seated on the cam snout if you are not careful.
Makes sense now why stan's engine was so lazy.
I bet that dowel was broken a while back allowing the cam to become retarded quite a bit.
PostPosted: Tue Jan 16, 2024 2:06 pm
I had forgotten to Locktite the bolt.
The cam bumper is what kept it close and not flying around in the cover.
I think it was loose on the last two runs, but not sheared.
It sheared on the return road when it quit running and would not restart.
Not the reason for it being lazy.
It ran it's best time by a half second on the second to last run.
PostPosted: Tue Jan 16, 2024 2:52 pm
That is one reason high performance big blocks went to the 3 bolt cam/sprocket.
PostPosted: Tue Jan 16, 2024 3:02 pm
And a few high output slants!
PostPosted: Tue Jan 16, 2024 3:41 pm
Us po folk cain't efford none that fancy crap.
PostPosted: Tue Jan 16, 2024 4:15 pm
Well if you didn't spend all your money on expensive motorcycles you could have some fancy stuff!!!!!!
PostPosted: Tue Jan 16, 2024 4:35 pm
:roll:
PostPosted: Wed Jan 17, 2024 6:40 am
Stan was there any signs of metal transfer on the crank flange?
PostPosted: Wed Jan 17, 2024 9:28 am
No Seymour, the crank, flywheel surfaces all look great.
Next week after it warms up a little I will pull the pan and look at the bearings.
PostPosted: Wed Jan 17, 2024 9:40 am
I guess that is good, but very odd it didn't tear up the crank coming off. :? :?
PostPosted: Wed Jan 17, 2024 2:47 pm
What do you mean Rick? I don't understand what you are saying.
It did mess up the front, enough to ruin the crank I don't know.
The rear flange is fine.
Splain it to me again.
PostPosted: Wed Jan 17, 2024 5:29 pm
When you said - "No Seymour, the crank, flywheel surfaces all look great." I thought you were saying the crank snout was Ok. I guess I misunderstood. :)
PostPosted: Thu Jan 18, 2024 6:47 am
No problem, I think he was wondering if I had a big imbalance in the crank rod assembly.
PostPosted: Wed Jan 24, 2024 8:10 am
I got the engine torn down yesterday.
Nothing unexpected.
Bearings looked very good, number 3 rod had a small discoloring down the center, could not feel anything.
Mains looked great.
Pistons as well.
My Racer Brown cam had a full grove rear journal, I didn't remember that!
Might explain the volume of oil on the rockers.
Now when time permits off to the machine shop to get advice on crank nose.
