It is currently Thu Oct 01, 2026 3:15 am
PostPosted: Sat Jan 27, 2024 8:47 am
First, I have ZERO luck removing one.
However the crank I am going to use is missing the key.
I guess it fell out.
Does anyone know what size key I need to find to install?
I have a small key here the right width, but it's square and it looks like I need a rectangular one.
Mine is .1845 square and it fits the damper keyway.
But it is almost flush with that slot.
Thanks
PostPosted: Sat Jan 27, 2024 9:54 am
Summit lists some. I think they have a little tail on each end. Just double check number below.
Mopar Replacement 6506397AA: Mopar Replacement Crankshaft Woodruff Keys
PostPosted: Sat Jan 27, 2024 9:57 am
Order one for a la or B/ RB engine.
They are the same.
I cut a slot into a piece of 1/8"-3/16" metal and weld the key to the slotted metal.
Then hammer on the welded mass for removal.
PostPosted: Sat Jan 27, 2024 4:45 pm
Thanks Rick, I found another one that looks closer, of course no stock till March.
PostPosted: Sat Jan 27, 2024 6:38 pm
The mopar part number for the key is 6029 411 and is the same for big block, small block and slant six.
https://hughesengines.com/Index/product ... rtid=11336
PostPosted: Sun Jan 28, 2024 8:19 am
Thanks Charrlie and Rick and Greg.
I will get a hold of Hughes and pay more in postage than the key cost!
Maybe I will get a life time supply while I am at it.
And buy the removal tool.
PostPosted: Tue Jan 30, 2024 9:30 am
Just ordered 4.
Postage was more than the parts.
PostPosted: Tue Jan 30, 2024 10:14 am
Those should ship to you for less than $6.00 The retail shipping rates are heavily inflated. use www.pirteship.com.
You just need to know the weight and X, Y, Z dimensions of the package.
All of those parts are probably less than 8 oz.
PostPosted: Tue Jan 30, 2024 1:28 pm
Shipping- $6.00 Yes
Shipping and handling same package- $29.99 :D :D
PostPosted: Tue Jan 30, 2024 3:42 pm
I have wasted a bunch more than that on my slant six dream (nightmare).
PostPosted: Tue Jan 30, 2024 8:18 pm
A wise man once told me "If I'd never met Seymour Peterson I could have saved myself $250K". :mrgreen:
PostPosted: Wed Jan 31, 2024 6:39 am
I bet that was Mike or Mark :shock:
PostPosted: Wed Jan 31, 2024 7:38 am
Probably both.
That would be a half a million.
PostPosted: Wed Jan 31, 2024 8:11 am
Probably both.
Yessir!
PostPosted: Wed Jan 31, 2024 8:32 am
My Opinion, Seymour was the one of greatest things that happened to Slant Sixes in my slant life time.
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 48 guests
