It is currently Fri Nov 14, 2025 4:41 am
Post new topic  Reply to topic  [ 767 posts ]  Go to page Previous 141 42 43 44 4552 Next
PostPosted: Mon Oct 09, 2023 3:06 am
Wouldn't it be cheaper to just run the tires half flat in the front? :D :D
PostPosted: Mon Oct 09, 2023 5:51 am
Maybe call Fatman Fabrications and see if they will make you custom drop spindles in the 9" drum specs?? You never know...
You also might be able to get BBP spindle hubs to fit your rotors and brake kit? I guess that would not help the caliper mounting, which is likely specific to that 9" spindle.
OTOH, it's just money...
PostPosted: Mon Oct 09, 2023 9:59 am
Yer killin me Smalls! :lol:
Lou, I looked at buying separate pieces to make my brakes work, but it would be cheaper to buy a whole kit. :oops:
Maybe my big project will be getting more gear in it. It liked 4.96s a lot, and I rarely run 1/4 anymore so I am going to try at least a 5.13 in it. IIRC I have a 5.38 ring and pinion laying around. Might built another pig.
On another note, I measured the valves in the head off the old motor in the car. They appear to be 1.66 and 1.44. Is that what the old MP valves were?
PostPosted: Mon Oct 09, 2023 10:12 am
What size are the stems?
PostPosted: Mon Oct 09, 2023 10:46 am
MP Valves were 1.70 / 1.44 I think
PostPosted: Mon Oct 09, 2023 4:42 pm
I did not measure.
PostPosted: Sun Feb 11, 2024 6:54 pm
More progress today. My son in law and my cousin helped me out today and we have the engine out and on the stand.
Next up, reseal the oil pan, remove the dipstick tube and install a plug, drill out the reat block drain and tap it so I can run the water feed into it, and paint the motor.
Just a few other minor things and we should be golden.
PostPosted: Mon Feb 12, 2024 4:16 am
Excellent! Nothing like some satisfying wrenching.
PostPosted: Mon Feb 12, 2024 8:57 am
Thanks Lou!
Luke the sil is 28 and really wants to learn about playing with cars. He's a good kid and good help.
Cousin Chad recently moved closer to the shop and has been helping a lot. It's great having family around.
PostPosted: Mon Feb 12, 2024 12:44 pm
Perhaps they will learn from your sharp wit!
PostPosted: Mon Feb 12, 2024 1:43 pm
Zilla, You may even run in the 13's!!! :D :D
PostPosted: Mon Feb 12, 2024 5:10 pm
Yeah, with his bad knees, 13 minutes would be about right :)
PostPosted: Mon Feb 12, 2024 6:17 pm
Do I need to slow down so you can keep up? :roll:
You guys are cracking me up. :lol:
PostPosted: Tue Feb 13, 2024 5:25 am
I still want to do a 1/4 mile drag race against a 225-powered airport tug... with me on a bike.
PostPosted: Tue Feb 13, 2024 6:23 am
I will bike sprint anyone at a 1/4 mile slant 6 race too.
Sounds fun! My bike has 21 gears or so and I might not even use all of ' em.
