It is currently Tue Oct 13, 2026 11:54 pm
PostPosted: Wed Mar 06, 2024 12:49 pm
Car Model: 1975 duster/ several other mopars
1st of all.Thank you for letting me join.i have a few mopars but thay been mothballed for 10 years.wife had cancer and passed away in 2022.so i am getting back working on my cars.i have a 1975 duster had a slant 6 in it.i was going to use as parts car but its in better shap than expected so i am going to make a daily driver out of it.mostly stock but put some work in the engine.so my questions are.i have a complete 1966 225 to use in it.how much can you deck the block and head to increse compression and how much compression can the stock rods handle?
PostPosted: Wed Mar 06, 2024 2:38 pm
If your car is a automatic, you will run into issues installing the 1966 engine into the 1975 car. You can install a 75 engine into a 66 car with only one minor issue, but going the other way is problematic.
As to your original question, some people have gone as much as .125 off the head, and about the same off the deck. That is too much for a "daily" driver.
PostPosted: Wed Mar 06, 2024 3:53 pm
Car Model: 1983 Dodge D150
Welcome to the site. I'm fairly new here as well.
Try a search for mill head compression site:slantsix.org
Lots of past threads to read. It's almost information overload.
I just had my block milled .07 You have to cc the head and measure deck height to calculate compression.
Good luck and sorry to hear about your wife.
PostPosted: Wed Mar 06, 2024 6:06 pm
What problems would i run into putting older /6 into 75?i do have a 75 block can i use the 66 head on it.i did cc the head its 62cc +or-2 cc.
PostPosted: Wed Mar 06, 2024 7:11 pm
I believe the pilot hole for the torque converter changed sizes.
PostPosted: Wed Mar 06, 2024 8:21 pm
I still have the torkconverter from the 66 ill have to see if it fits into the 74 trans.
PostPosted: Wed Mar 06, 2024 11:16 pm
It will physically fit, but it won't work. The input shaft is different.
PostPosted: Thu Mar 07, 2024 6:33 am
Car Model: 1975 Dodge D100
It's doable. My current engine is a '64. I had the machine shop enlarge the crank pocket to fit the torque converter for my '75 transmission.
PostPosted: Thu Mar 07, 2024 8:35 am
Thank you.that was going to be my next question was if a shop can enlarge that or will a newer forge crank fit an old block?also how much compresson can stock rods take?thx
PostPosted: Thu Mar 07, 2024 10:28 am
Also if i deck the head or block do i need to get diffrent push rods or is that a non issue with ajustible rocker arms?
PostPosted: Thu Mar 07, 2024 6:03 pm
Yup a newer forged crank will fit that block... I had to do just that when I found out about the converter hub size mismatch the hard way when I did an engine swap and they wouldn't go together. I ended up having the 73 crank in the bad engine reground and put it in a 63 block. This was about 35 years ago.
PostPosted: Thu Mar 07, 2024 6:04 pm
Do a search, most of these questions have been asked and answered a million times over the years. If you go back and read older posts you'll see the same questions cycle around over and over
PostPosted: Fri Mar 08, 2024 12:06 pm
Thank you.for your help
PostPosted: Fri Mar 08, 2024 3:14 pm
I have asked questions here then searched and found the answer. Have learned to search first. Though most results are old, most of the time the info is still good and relevant. I need to figure out how to search for recent results for paint recommendations. Going to search for that now. :lol:
PostPosted: Fri Mar 08, 2024 6:00 pm
Your rods can handle all the compression you are going to make. Only the most serious engine build would need aftermarket rods.
