It is currently Fri May 15, 2026 11:02 pm
PostPosted: Mon Aug 16, 2004 1:02 pm
I'm totally replacing all ball joints and bushings but wasn't considering the strut rod bushings. Should I replace those as well while I'm at it? Do they effect handling much since they attach to the lower control arm?
Thanks
PostPosted: Mon Aug 16, 2004 2:13 pm
YES. Get the MOOG improved type bushings. You will kick yourself hard if you don't and they go bad in a year or two (likely). You have to pull T-bars back and usually upper or lower balljoints to get the SRs out.
PostPosted: Mon Aug 16, 2004 2:56 pm
Rule of thumb:
If it's got the pentastar symbol on it, the strut-rod bushings need replacing whether you know it or not :!: :idea:
D/W
If it ain't broke, fix it!
PostPosted: Mon Aug 16, 2004 4:17 pm
Is there 2 bushings per strut or just the big one in the front?
Thanks
PostPosted: Mon Aug 16, 2004 5:40 pm
The bushing set goes in front of and behind the K-frame so you need to pull the rod completely back out of the K. The MOOG kit does both sides complete.
PostPosted: Mon Aug 16, 2004 11:06 pm
So there is no bushing in the LCA?
PostPosted: Mon Aug 16, 2004 11:19 pm
Yes, there is another rubber bushing hidden deep inside the lower control arm. I got some from JC Whitney a few years ago for $5 each back then.
PostPosted: Tue Aug 17, 2004 6:48 am
The strut rod does not ride in a bushing in the LCA, it is nutted down solid on a tapered section. The LCA does have its own bushing at its K frame mount point.
PostPosted: Tue Aug 17, 2004 1:03 pm
re: do they affect handling that much?
YES
They are keeping the LCA in position (fore/aft) and carrying the braking load.
As a test, while you have the strut disconnected, tug the LCA backwards and see how far it goes, then imagine the load it sees under braking/cornering! :shock:
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
