It is currently Wed Jun 03, 2026 12:12 pm
Post new topic  Reply to topic  [ 1209 posts ]  Go to page Previous 163 64 65 66 6781 Next
PostPosted: Sat Mar 30, 2024 3:54 pm
Just use the silicone and no lube. Looks like a simple fix. You don't need tons of torque on the rocker shaft anyway. 40-45 ft-lbs (by feel) is usually what I do. Use Ultra Black or similar.
PostPosted: Sun Mar 31, 2024 2:23 am
How about "Locktite" thread sealer?
PostPosted: Sun Mar 31, 2024 5:15 am
Probably? I've never used it. Product review?? ;)
PostPosted: Sun Mar 31, 2024 6:23 am
I'll have to get the product number from the bottle out in the shop. I use several different locktight products.
Red thread locker
Blue thread locker
Stud and bearing mount
Thread sealant
Not inexpensive, but I like their products.
PostPosted: Sun Mar 31, 2024 8:49 am
I am guessing you use studs on these. So you could use something semi-permanent and then not have to worry about taking the stands off?
PostPosted: Sun Mar 31, 2024 9:46 am
He said just put silicon on them.
How do you use silicon and bolt lube, like ARP goop, together?
Just use the silicone. The gray Mopar stuff would be best.
PostPosted: Sun Mar 31, 2024 12:53 pm
The arp thread sealer can work too.
I am convinced that is is regular plumbing thread dope.
:D
Good luck!
PostPosted: Sun Mar 31, 2024 6:18 pm
Car Model: 1975 Dodge D100
I’ve used the Loctite thread sealant on manifold studs, water pump mounting bolts, temp gauge fittings, plugs, anywhere threaded parts are exposed to the cooling system. Applied per the manufacturer directions, I’ve had not issues on any of these applications.
PostPosted: Sun Mar 31, 2024 7:14 pm
I looked at my bottle, but the label is unreadable, so I don't know the part number. didn't have time to try and look it up. Locktite products are pricey, but they do work as advertised.
PostPosted: Sun Mar 31, 2024 8:31 pm
Loctite 592 is the one I have used. It's good stuff.
PostPosted: Mon Apr 01, 2024 1:35 am
Also, Permatex #56521 High Performance Thread Sealant.
PostPosted: Mon Apr 01, 2024 5:52 am
Thanks everyone!
PostPosted: Tue Apr 02, 2024 5:36 pm
Waiting on the head I threw these in to see if they might fit.
Close.
PostPosted: Wed Apr 03, 2024 6:26 am
Those look like some skookum as frig big headers. Did you just build them or did they come from another project?
PostPosted: Wed Apr 03, 2024 7:15 am
They are from another project.
They would need quite a few modifications to work in my Colt.
