It is currently Sat Oct 24, 2026 8:47 am
PostPosted: Sun Apr 07, 2024 6:45 pm
Car Model: 81 d 150/ 5 speed/clifford /holley 390/hooker hd
Hello All
I just bolted the engine to a stand this afternoon and plan to start cleaning it up tomorrow .
Would like some paint that will somewhat mimic factory color and wont object to the heat ...
This is a good ole boy fixup ,only trying to please me and preserve it for my helper /son .
I have been sandblasting /wirewheeling the frame and using Rust Bullet Black Shell brushed on . It looks better than than it should !
Any tips would sure be appreciated .
Unclebear
PostPosted: Mon Apr 08, 2024 4:48 am
Does the 1981 Engine Come in Blue or black?, I cant Remember.
I know Lou paints most of his engines black I am sure he has a good recommendation for Black.
For Blue you could use something like this:
https://www.oreillyauto.com/detail/c/en ... plg/de1631
I am not sure if it is the best that is out there, but it will work.
PostPosted: Mon Apr 08, 2024 6:53 am
There were a few traces of blue on the bell housing and engine.
When the engine was rebuilt in 1989 the builder used red.
PostPosted: Mon Apr 08, 2024 7:06 am
If you wanted to use red, I have used this before with good results:
AutoZone has the best price on this paint.
you can get it elsewhere too.
It's not the factory MoPar correct red.
https://www.autozone.com/paint-and-body ... 550962_0_0
Maybe Dan will chime in with some insights as well.
PostPosted: Mon Apr 08, 2024 9:56 am
Car Model: 1983 Dodge D150
The switch from blue to black was around 83. My 83 was black but got painted blue recently with rustoleum spray can. Can't say how it holds up as the engine is still on the stand. Prep work is most important. Get it clean.
PostPosted: Tue Apr 09, 2024 7:00 am
I've had excellent results with Rustoleum Engine Enamel.
--> The Diesel Corvette <--
PostPosted: Tue Apr 09, 2024 9:06 am
Rustoleum it is then !
Thank You for the advice.
