It is currently Thu Oct 08, 2026 7:57 am
 Post subject: Which clutch??
PostPosted: Thu Apr 25, 2024 8:39 pm
Car Model: 78’ dodge D100 slant six
Two types of clutches are available. 3 lever style and diaphragm style. Which one is best? 1978 d100 with slant six and 3 speed manual a230 trans.
 Post subject: Re: Which clutch??
PostPosted: Fri Apr 26, 2024 4:49 am
Well, if you are looking at a Rockauto Calalog / website. that diaphragm unit is probably mislabeled or misapplied.
Either pressure plate will work fine in a stock application.
Usually for the slant 6, the diaphragm unit is a custom/aftermarket/ use of another oe application to fit onto the slant 6 flywheel. All of the factory OE slant 6 pressure plates would have been the 3-finger style.
What is your Flywheel ring gear tooth count?
PostPosted: Mon May 06, 2024 4:30 am
That’s a good question Greg. I’m not really sure.
PostPosted: Mon May 06, 2024 4:40 am
Post a picture of your bell housing/starter area or count the teeth on your flywheel.
Trucks did have a few bell housing/flywheel configurations from what I can tell.
Users browsing this forum: No registered users and 20 guests
