It is currently Tue Jun 16, 2026 8:34 am
PostPosted: Wed Aug 18, 2004 4:41 am
Will a Manual bolt up to a /6 that originaly came with an auto or are the cranks different? Thanks, Kyle.
PostPosted: Wed Aug 18, 2004 6:18 am
The cranks are the same, but there is a split between '69 and '68 in crank hub size. In '69 they went to a larger hub. This should effect your auto tranny only. When going to a stick shift, you need to have a pilot bushing in the recess at the back of the crank, to accept the input shaft of the manual tranny. All of the auto cranks I have seen already had the bushing installed at the factory, even if they were factory auto trannies. If it is not there, just ask for a input shaft bushing for the year of your engine, and install it. They seldom wear out, so it one is there, it is probably safe to just use it.
Users browsing this forum: Ahrefs [Bot], mcnoople and 2 guests
