It is currently Sun Oct 25, 2026 9:30 am
Post new topic  Reply to topic  [ 52 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Thu May 02, 2024 6:22 am
Car Model: 1983 Dodge D150
Don't want to bring up the uncle Tony battle about running pistons backwards again but I'm sure it's coming
Sorry, didn't realize there was battle. I did search and found only a post or two.
PostPosted: Thu May 02, 2024 2:57 pm
There have been more than "a post or2" from him on you tube on the subject.
And a firestorm from members of sites such as FABO among members picking him apart
PostPosted: Fri May 03, 2024 11:57 am
I searched backwards piston. Didn't search for uncle Tony.
Thanks. I'll edit the previous post.
PostPosted: Fri May 03, 2024 5:38 pm
You won't have to look hard, he's all over you tube.
Lots of controversy over what he posts.....
PostPosted: Fri May 10, 2024 3:10 pm
Pistons corrected. Ready to go in again. Installed old cam gear and spun the cam and oil pump for a bit. Turns much more freely now.
Was going to install the new rollmaster timing chain and the cam sprocket doesn't seem right. Factory has a boss that centers the gear on the cam. New gear has nothing. Am I missing something here? Nothing to center the new cam gear on the cam. Nothing to hold it in the right position forward and aft.
Eta: Does the chain center the cam gear?
PostPosted: Fri May 10, 2024 5:35 pm
No, Sum-Ting-Wong, chain can't center it. Part# on that T-kit?
PostPosted: Fri May 10, 2024 6:05 pm
The center holes look different sizes too?
PostPosted: Sat May 11, 2024 6:07 am
https://www.ebay.com/itm/263577823687?m ... media=COPY
PostPosted: Sat May 11, 2024 11:19 am
Nope, It looks like you have the wrong gear. Or at least one that was not finished with the recess for the cam. Center hole still looks large to me?
PostPosted: Sat May 11, 2024 6:44 pm
Picture shows the rim that isn't there. May just have to buy another. I'll wait till Monday to see if they respond. It is outside the return period so don't blame them if they don't accept a return.
PostPosted: Fri May 24, 2024 4:40 am
Ordered another cam chain set and the cam gear is slotted. Don't think I can use a button to adjust degree with this. The picture looked like the stock gear with 2 holes. Does anyone know of a place to get the right cam gear?
PostPosted: Fri May 24, 2024 5:29 am
What happened to your original double roller set? The new one looks to be the stock type gear? Wouldn’t the company send you the correct set?
PostPosted: Fri May 24, 2024 5:41 am
The double roller set had the wrong cam gear. Think it was for a big block. They did accept a return.
I would install this set and see how far off it is but then wouldn't feel right returning it. Was going to drill out the cam pin hole and use a bushing to degree the cam. Don't think that is possible with this slotted cam gear.
PostPosted: Fri May 24, 2024 9:32 am
Go to Rock auto and lock it up on there. I don't like the slotted one. I think I got my last set at Auto Zone and it was correct. ( No slot)
PostPosted: Fri May 31, 2024 1:30 pm
2 more timing chain sets have showed up with the slotted cam gear and are going back.
Found this: https://www.ebay.com/itm/266459928542?m ... media=COPY
Will a sealed power gear work with a Cloyes chain? One of the sets was bought as pieces and I could return the cam gear. Use the Cloyes chain and crank gear.
