It is currently Fri Oct 23, 2026 5:31 pm
 Post subject: '63 Dart problem
PostPosted: Sat May 18, 2024 10:15 am
Car Model: 1963 Dodge Dart GT convertible
Need suggestions re: my 1963 Dart, rebuilt 225 with a Holley 1920
Was running great, rolled up to a stop sign and it suddenly started running very bad - gasping and sputtering - and died... restarted and instantly ran great, as if nothing had never happened. My mechanic confirmed the points looked a little crispy so we did a points and condenser swap + tune up, which were overdue. Checked vacuum lines and they look fine.
However now it’s still the exact same, runs perfectly then out of the blue it will run very rough and die, but immediately starts right back up.
Trying to figure why restarting “resets” whatever is causing it to go momentarily haywire before it goes Ker-Plunk. Thinking the 1bb Holley carb needs a rebuild but perhaps someone smarter than me has a suggestion before I go down the rabbit hole...
thanks in advance!
 Post subject: Re: '63 Dart problem
PostPosted: Sat May 18, 2024 10:51 am
Check / replace the fuel filter, then the in tank sock filter,
It could also be some intermittent electrical gremlin at the firewall bulkhead connections.
Good luck,
PostPosted: Sat May 18, 2024 11:21 am
Ditto on the bulkhead connector, especially the light blue wire that runs to the ballast for the coil.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 12 guests
