It is currently Sat Oct 10, 2026 12:34 pm
Post new topic  Reply to topic  [ 148 posts ]  Go to page Previous 1 … 6 7 8 9 10
 Post subject: Re: Back in black II!
PostPosted: Thu Jul 11, 2019 11:46 pm
Moving the trans rearward may require trans tunnel mods. I had to hammer mine a little to fit. Also look at the firewall area, it is tight there on the trucks.
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Fri Jul 12, 2019 9:17 am
I have no trans tunnel on the truck, just wide open space. I am thinking Lou's suggestion of slightly moving the engine forward and the trans backward is a good one. That would mean each moved less than an inch which would require fewer modifications. However, I know I am going to have to put the truck up on jackstands, pull the 727, and spend some time measuring and thinking about things before I install. I need to have a new driveshaft made, anyway.
PostPosted: Sun Aug 18, 2019 12:50 pm
I took advantage of my brother visiting today and swapped the bed. After having a stepside bed sitting in my yard for four or five years, I FINALLY installed it:
Still have to finish up little details like fixing a ripped out taillight mounting bolt, getting all the crossmembers installed. Getting the rear of the bed mounted to the frame, etc... but the heavy lifting is done.
PostPosted: Sun Aug 18, 2019 1:41 pm
Iiiiiii like it!
PostPosted: Sun Aug 18, 2019 1:55 pm
Yep, slowly getting better.
PostPosted: Sun Aug 18, 2019 5:13 pm
swapped the bed
L :D :D KS G :D :D D
PostPosted: Mon Sep 25, 2023 7:24 pm
I'm still here! I'm still above ground! Still chipping away slowly on this project truck!
Since the last update, I have swapped the carb to a 500 CFM Carter AFB run on a Super Six intake with an adapter and then to a Holley 2300 Economaster run on the same intake with an adapter.
The truck is still chugging along as well as an unrestored 47 year old daily driver hauling vehicle can be expected to run. That is to say, it is really on its last legs and neds to eb parked and worked on. Its keeps on going but EVERYTHING needs work. I am working up to finally stuffing it in the garage and blowing it apart for a full resoration. The fuel gauge quit working so it really isn't a reliable driver anymore.
Who knows what the future will hold. I may go to the dark side and update the drivetrain to a more modern four speed auto and *gasp* a V-8. Or not. We will see.
I will update as time, money, and advancement on the project permit.
PostPosted: Sat Jun 08, 2024 10:30 pm
Well, ten months later and nothing has changed on my truck but the mileage. However! In a couple weeks I will be taking it over to my brother's house for a cosmetic refresh. He has some extra satin black paint from Eastwood that he bought for a project and activated but did not use. So we will be do a quick and dirty repaint of as much of my truck as the activated paint will cover. Going to start with the bed since it was originally red but I painted it black with rattle can Duplicolor paint from Autozone. Needless to say the bed is blackish-gray and looks terrible. Pictures to follow of the new paint job.
PostPosted: Sun Jun 09, 2024 3:38 am
Nice to see you back here, Reed. Best of luck with your projects!
PostPosted: Sun Jun 09, 2024 11:05 am
Thanks. Plans for my truck include an A500 installation, forced induction, and fuel injection. Fingers crossed I will actually be able to make them happen.
PostPosted: Mon Dec 22, 2025 12:45 am
Good grief. I suddenly find myself ten years older with virtually no progress made on this truck. Maybe next year? :roll: In my defense, it has been an eventful ten years. A worldwide pandemic, five career changes, new family members, I'm ready for a break. Hopefully this next year will bring some stability and the resources to get back into the car hobby.
PostPosted: Mon Dec 22, 2025 3:36 am
Best of luck, Reed. Life always changes and we all need to keep changing priorities and focus areas. If you really want to work on the truck, I think you can make it happen. Yes, stability is often the hardest part... Hang in there. Let me know if you have any parts needs or want to talk about anything.
Warm wishes,
PostPosted: Sat Feb 14, 2026 10:59 pm
And here we are, two months later!
I actually have progress to report. Front end rebuild has begun. I got the entire steering linkage, knuckle to knuckle replaced tonight.
Picture is crappy because I blew out the shadows to show the contrast between the old linkage on the ground and th enew linkage installed in the truck.
Waiting on some tools and parts to arrive before I tackle the ball joints, control arm bushings, brake lines, and shocks.
I think next I will pull the 727 and do a quick and dirty rebuild
Then do a compression check on the engine and pull it to either do a thorough regasket and finally install a four barrel intake (thanks again, Wes!) or, if the engine is too worn torealistically be reinstalled, figure out a substitute while the slant gets a full rebuild.
Onward and upward!
