It is currently Fri Oct 23, 2026 9:09 pm
PostPosted: Sun Jan 07, 2024 1:42 pm
WOW, that is a serious crack, I wonder what caused that?
Could you see any other damage, like a frozen water cracks?
PostPosted: Sun Jan 07, 2024 3:34 pm
Yikes. Might still be able to sleeve it... BTW, Will Burns got an alum engine from me that had multiple cylinders that looked like that and he said he could fix it.
PostPosted: Sun Jan 07, 2024 10:13 pm
Car Model: 1966 2D Dart
Hey I have uploaded a pic of no5 cylinder the crack is the whole way through.
Please take the head gasket off and show us how does the the aluminum cast be around that much cracked sleeve? Hard to believe the cast iron can expand that much without damaging the thin alloy cast.
PostPosted: Fri Jun 14, 2024 6:09 am
Car Model: vc valiant
Hi all check what I found and now own in Australia [quote][/quote]
PostPosted: Fri Jun 14, 2024 6:35 am
It looks like you have an empty quote.
Check that coding and syntax, and get back to us.
I bet it's fantastic.
PostPosted: Fri Jun 14, 2024 6:39 am
Additionally if you need more help / info on the Alloy blocks special parts aside from the head gasket.
See Here
PostPosted: Mon Jun 17, 2024 9:16 am
If I had that in my shop I would certainly put a liner in it. I and many others have very successfully put sleeves in blocks far worse off than that one. Hope you didnt give up on it!
I make rusty parts go fast. Norm
71 Road Runner
65 Valiant SW
79 Lil Red Express
78 D-300 Club Cab
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 16 guests
