It is currently Fri May 01, 2026 2:11 pm
PostPosted: Sun Aug 22, 2004 10:48 am
What do you recomend in a 1976 a-833 o/d cast iron case trans.I have a factory service manual for 72 that recomends atf in the 833(except in CA where they still say 80/90 gear lube). when I drained my trans it had gear lube in it. Thanks in advance.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
PostPosted: Sun Aug 22, 2004 11:13 am
...all depends on how much power you want to lose in the slush-box...
D/W
If it ain't broke, fix it!
 Post subject: Temp and 'duty'...
PostPosted: Sun Aug 22, 2004 1:00 pm
If you're average temperature is 'warm' then gear lube would be better. If you're drag racing ATF is the trick, if driving it on the street all the time then 90Wt GL-4 lube is better. The other trick is that the mating surfaces tend to 'warp' a bit and not seal so good after 30 years on these boxes, and ATF will bleed out faster than the 90Wt.....
Pick what you feel is the best 'compromise' for what you're going to do with the car.
PostPosted: Sun Aug 22, 2004 4:50 pm
Thanks guys,how much do you think I would lose with the 80/90 and if go with atf--dextron or type f??
HyperValiant
PostPosted: Mon Aug 23, 2004 12:02 pm
Dexron.
PostPosted: Thu Sep 02, 2004 7:50 am
Well, I just put a 75 A833 in a a 65 dart and the shop I bought the parts from said damn near anythin would work, he reccomends with thirty years experience about 20w50 engine oil for moderate climates.
