It is currently Thu Oct 22, 2026 6:56 am
 Post subject: Slant 6 wrecker?
PostPosted: Sun Nov 17, 2024 10:17 am
Car Model: 1961 Dodge 300
Toying with idea of replacing 318 poly, that needs replacing, like idea of putting in a mild slant 6, but, but, but, it's a dump truck, but want to convert it to a wrecker, it's a 1961 d300, has granny 4 speed, and geared low. Was thinking the 6 would be a great motor for mileage, especially with all idle time, but am I'm I expecting too much? The hiway and interstates may be pushing limits? Opinions?
 Post subject: Re: Slant 6 wrecker?
PostPosted: Sun Nov 17, 2024 1:38 pm
Online
Site Admin
Welcome here!
Using a slant for a wrecker on today's roads, I'd think would depend on your expectations.
I don't think it would be an ideal choice for a working wrecker frequently found on the interstate. I'd be looking for more cubes, or a diesel swap.
For infrequent trips at 55 or less, or as a personal tool, it may be OK. It's not going to be able to keep up with the big dogs, but with patience, should be able to do the job.
CJ
PostPosted: Mon Nov 18, 2024 8:26 am
Welcome here!
CJ
PostPosted: Mon Nov 18, 2024 8:27 am
Welcome here!
CJ
Semi afraid of that, approx 10 major hiways / interstates within 30 mins, 5 are within 10 miles. I know would warm the slant 6 up, but mildly, water/methanol injection to keep hard running in check so no possibility of detonation, but want extremely reliable, great gas mileage, I'm not a fan of any diesel. I thought mild cam, 4bbl using Holley Economaster, vintage carb, shaved head, header, I built many engines for mileage, but nothing like this project.
PostPosted: Mon Nov 18, 2024 9:57 am
Chrysler built 6 ton dump trucks in the 60s powered by the slant six, but they got away with it by using four speed transmissions, two speed rear axles, and a top speed of around 50 MPH. As already stated, if you intend to use this truck on modern roads and actually haul things with it, you are better off getting a more powerful engine that can keep up with traffic with lower driveline gearing.
PostPosted: Mon Nov 18, 2024 2:07 pm
I'd say probably yes. Once you start talking Heavy wrecker and low gearing and warmed over slant 6, you are not going to get any kind of great mileage. Maybe in a D100 ( which I have) yes you can get really decent mileage and have a nice running truck, But adding a bunch of weight and low gears hurts everything.
PostPosted: Mon Nov 18, 2024 4:45 pm
I understand. I owned a few wood trucks,plus 2 roll backs long ago, plus drove a rollback for few years, never saw over 10 mpg 6-8mpg with small blocks, big blocks, even a 78 Dodge with 318, was wondering if could push closer to 12mpg? Plus idle savings? I was guessing running at least 1k miles a week, if save 2-4 mpg, with price of gas, could be big savings? Plus only behing seat tank, my old 60 Ford had behind seat tank, barely got 120 miles per tank, I know aux tank probably will be necessary? But not ran tows I. Over decade, but now want to get back into it, plus hate my job. Lol
I own truck, also have 3 wrecker boom assemblies, but will need to pull dump bed off. Already has PTO, so could use hydraulic winch, or go electric. But will need engine, plus minor fixing up. I tried to upload pic, said my Pic is too large, no idea how to down size Pic.
PostPosted: Tue Nov 19, 2024 6:20 am
I am a slant-six-guy,
But I would definitely rebuild and keep the 318 Poly, those are really cool motors.
And if I could not do that get a modern Hemi out of a Dodge truck. Conversation kits to carburate those are available.
PostPosted: Tue Nov 19, 2024 5:01 pm
After having several 318 poly motors in my life, not a big fan of, too hard to get parts for, so if need simple seal or gasket. Maybe get lucky, or wait several days to get, or maybe have to order online, so definitely want engine I can find most parts for easily, not researched newer Hemis, but I'm very old school, so simple, basic, but total reliable, plus mileage
PostPosted: Tue Nov 19, 2024 6:07 pm
'too hard to get parts for,'
you do realize that slants have not been sold in vehicles for over 30 years.
Any serious slant guy is going to keep a stash of head gaskets, water / oil pumps and gaskets / ignition and fuel system parts within arms reach.
As the truck you are working with has some age, it seems that it would be wise for you to do the same with brake and steering and suspension parts.
Having a set of Poly parts and gaskets tucked away under the work bench may simplify your life.
If you are serious about needing good fuel milage and reliability in a vehicle that will weigh north of 5000 lbs empty, a Cummins 6B would be a much better solution than a slant.
PostPosted: Wed Nov 20, 2024 9:44 am
Why? I have traveled in over half the US by Harley, wouldn't hesitate to go anywhere, whether my 1973, 1961, or 1942, only have few minor spare parts, can get anything within 1 week. Yes I'm a qualified mechanic, built those bikes from scratch, I plan to go over truck. But not worried on age of engine, no interest in diesel, figure cost of ownership, mileage, repairs, per every 10k miles, gas will always be close, and 1 major diesel repair, it loses, versus a rebuilt gas engine, especially since I can do all repairs myself. Even use friends machine shop for boring, balancing crank, valve work, or even simple rebuilding heads
PostPosted: Wed Nov 20, 2024 1:05 pm
I like the slant. But if you want a ruggedly reliable engine with decent fuel economy and the ability to propel a tow truck then the cummins 12/24 valve swap is a much better choice. It will get you better fuel efficiency AND ability to pull when needed. The slant will likely be cheaper (but then again so would a more modern 5.2/5.9 magnum swap) compared to a the diesel swap, but you would get much less out of it.
PostPosted: Thu Nov 21, 2024 6:39 am
Online
Site Admin
Well, we're back to square one. The slant will move the truck, and with expectations set, you can pull quite a load. Perhaps not at "freeway" speeds.
I have a buddy that has a 1946 International wrecker. It's got a five speed with a splitter rotated by a 586 CI Six. Nasty torque monster. He tops out in the mid-single digit mpg. I think the governor pops in around 3k. He does not take it out on the freeway. It's a private use type of wrecker. It's got the market cornered on cool though! I don't think he would want to insure it for commercial use, like his dump truck. He doesn't carry those on his Over-the-road business. He has them on his farm account IIRC. He scored his 4700 dump from a GC that got tired of carrying insurance on it, and it was a bunch newer. 80's? Those all look the same to me.
CJ
PostPosted: Thu Nov 21, 2024 8:36 am
Can't beat the Slant for simplicity and it seems you really want to try it, so why the heck not. I'd get the AEM water/meth injection kit to stave off any preignition under heavy load. Don't expect to tow at high speed. We can help you build a good torque motor.
Are you good with pump premium gas, or will you require running on 87 octane?
PostPosted: Tue Dec 10, 2024 8:00 pm
Car Model: Slant Six M37
A slant 6 is a great engine.. but I am afraid you would not be happy with the end result in a one ton truck... I know Dodge put them in D500's.. and I would love to drive one, but only in a parade, or for coffee.. NOT trying to get somewhere, with a load on the back!
I've got a 67 D300 slant 6 cab chassis that might have been a wrecker or a dump truck.. it has 4.88 gears and fairly short tires on the rear.. shorter than a 7.50-16 I believe. The 300 series trucks could have 5.83 ish or 4.88 gears in the Dana 70... and it would be fine in the field, or around town.. I spoke with a fella Sweptline owner in Texas a few years ago who was of the opinion that all of the sweptline trucks were underpowered with a 318 of any type.. I think he is probably right in most instances and it effected my planning for my W300..
Pre '68 (?) The 6 lug brake drums that are hard to find.. and you will want good brakes!!! I am going to use square body chevy axles, as they are almost a bolt in... and that solves front and rear brake drum issues, as well as the really low axle gears... if you have the engine to turn a higher gear.
As for the slant 6 in a work truck: I Had to have a 3/4 ton 4X4 with a slant 6 so I converted an engineless M37.. as much as I love it..and I do, it gets 6 MPG.. when I am working it.. plowing snow or hauling wood... I've never taken it on a road trip so I don't know what it will do on the open road with out a load on. Not saying it couldn't do any better, but at the moment that is what it is getting... It has good power empty... but loaded with enough firewood to settle the rear springs, Hills are more of a challenge.. I have done a timing re-curve and a 2.5" exhaust. I am planning more adjustments over time for the fun and education.. I have heard of a D300 with a slant 6 getting 16 or 18 MPG unloaded. I would backflip once or twice if my M37 could touch 14-15 empty someday..
I would vote for a 5.9 magnum gas engine. I believe they bolt up to your Bellhousing. You would need a weighted flywheel for the magnum and a spacer between the flywheel and the crank flange because the hydro bell housing is different than the later mechanical set ups.. Maybe the best way is to get the Poly's flywheel balanced to 5.9n Magnum specs?... then you have 300 HP and loads of torque.. and likely no need to rebuild it! (That is my plan for my 61 W300 frame)
A diesel will work, but it is more working expense to fit and RPM limited when using low rear gears.. the first Gen Dodge trucks had something like a 3.08 rear gear on the automatics, and 3.54 gears in the 5 speed with the Getrag overdrive transmission.. and about a 70m MPH top speed..
The sweptline forum will have a bunch of thoughts and opinions from people who own and run the one ton sweptline trucks.. and lots of advice on how to upgrade everything on them to be a better version of itself..
Users browsing this forum: Amazon [Bot] and 17 guests
