It is currently Sun Jun 21, 2026 8:44 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Thu Dec 19, 2024 4:53 pm
This is all relative to a point. Is this your first Dodge truck of this era? Do you have anything to compare to?
A soft ride to some may be a harsh ride to others.
But yeah to a point of being too bouncey even if this is your first one or only one what shocks did you get?
Monroe for instance markets at least 3 different grades of shocks for these trucks and to install set a, drive it, come back and put on set B and go for a drive, then come back and try set C, there will be a difference in how a given vehicle will ride. There isa chance that you got a defective set too.
I've had kyb shocks on a Dakota, I took them off and threw them away within 2 weeks as I didn't like them. The blue "oe equivalent" entry level Monroe ones likewise are a waste.
I pot rancho ones on my 2012 and they seem alright in the front but the back ones are crappy. All are same grade, (rancho 5000 if I remember correctly) and guess what rancho is made by Monroe.
I'm probably going to look and see if I can find some Gabriel ultras like I told you about for my '12 (Dodge ram 1500 reg cab long bed) to replace the rancho's.
PostPosted: Sat Dec 21, 2024 6:29 am
It is my first dodge of this era but i also have a 83 f150 an it rides smooth compared to the dodge. And yes i got those ultras that you told me about. Ill probably change out the springs that might be the issue
Users browsing this forum: Ahrefs [Bot] and 1 guest
