It is currently Thu Oct 22, 2026 8:05 am
PostPosted: Wed Mar 12, 2025 11:15 pm
Car Model: 1964 Plymouth Barracuda
I will be putting a post ‘67 225 slant and and a ‘72 model 904 (the sliding yoke style) in my ‘64 Barracuda (originally a V8 car). Will ‘67-‘72 style A body (or another body for that matter) motor mount brackets fit in this combination? I read somewhere that doing so technically fits but, on a manual transmission, it pushes the engine or bell housing into the Z bar and causes clutch action problems. Will doing this in an automatic car push the transmission back too far as to touch the firewall/transmission tunnel or interfere with the fit or travel of the driveshaft and/or yoke? Thanks!
PostPosted: Thu Mar 13, 2025 8:45 am
If my memory serves me correctly, they are very different, especially the passenger side.
PostPosted: Thu Mar 13, 2025 5:49 pm
You need a pair of '62-'66 Slant-6 motor mount brackets for this install.
PostPosted: Thu Mar 13, 2025 6:24 pm
Thanks for the info. Nothing worse than buying a set of the wrong brackets “on a hunch” that won’t fit and will sit in my shop for the next decade! Happy to avoid it … for once!
PostPosted: Fri Mar 14, 2025 4:27 am
You will also need to use the early (66 down) oil pan and pick up tube.
PostPosted: Fri Mar 14, 2025 9:36 am
Is the pan necessary on a car that has the V8 center link. My memory is that sumps are in the same place but the less girthy on the early engine, but this is a 30 year since last dealing with it memory.
PostPosted: Fri Mar 14, 2025 2:44 pm
No, the sumps are located differently. You will need the '60-'66 pan and pickup.
Also a set of '62-'66 motor mounts. Crummy compressed-cow-poo items from the parts store or the good ones from Polybushings (have a conversation with Johnny @ Polybushings if you want a softer-than-he-usually-makes set of them).
PostPosted: Fri Mar 14, 2025 2:48 pm
pics of pans. https://www.slantsix.org/forum/viewtopic.php?t=3337
PostPosted: Fri Mar 14, 2025 5:39 pm
You can also notch the K-frame on the RH side and then use the "center" sump pan ( Blue one in the picture) off the later engine . Of course you need to reinforce the area you cut. Early pans are not on every corner anymore. :D
PostPosted: Sat Mar 15, 2025 5:08 am
I have 2 laying around. :mrgreen:
PostPosted: Sun Mar 16, 2025 10:35 am
A F-Body oil pan and pickup along with the '64 - '66 V8 center link will work. The oil pan needs to be notched on the driver side front corner for clearance. Much easier the notching the K-member.
PostPosted: Sun Mar 16, 2025 10:12 pm
‘62-‘66 mounts? If you want to sell a set, let me know?
PostPosted: Sun Mar 16, 2025 10:20 pm
If by saying “notched on the driver side front corner for clearance” you mean give it a few whacks with a hammer, that sounds preferable to me than cutting on the K member. Honestly, if you mean cut a section out of the pan and weld in a flat piece of metal in it’s place to gain clearance that also sounds preferable to cutting the K … just more effort.
I have been eyeballing an engine out of a truck (year unknown; originality of engine to this truck unknown), so I have no idea what oil pan is on it.
PostPosted: Mon Mar 17, 2025 10:45 am
Oil pans.
If I spent a day digging around at my shop I might have the mounts, but might never find them.
PostPosted: Mon Mar 17, 2025 3:32 pm
Oil pans.
If you happen onto one that you want to sell, it me know. No rush.
Users browsing this forum: Amazon [Bot], Bing [Bot], DuckDuckGo [Bot] and 26 guests
