It is currently Tue May 19, 2026 1:21 am
PostPosted: Wed Aug 25, 2004 11:05 pm
Hi Gang,
I have a power steering gear box that leaks fluid all over the place from the sector shaft adjusting screw. This pic should explain it all. I have tried on more than one occasion to tighten the nut and it still leaks. I might have tweaked something by overtightening. How might I fix this problem outside of replacing the whole unit? I could keep adding fluid but I hate the thought of polluting the reasonably pristine Oregon environment.
Thanks,
Tom
 Post subject: Try....
PostPosted: Thu Aug 26, 2004 10:42 am
Try a brass plumbing washer. Might help, depending on why it's leaking.
1980 Aspen 225 super six
PostPosted: Thu Aug 26, 2004 8:10 pm
There is usually an aluminum ID tag under the nut that also works as a seal. I don't remember right now if the center of the hole in the ID tag has a rubber center or not.
Either way, looks like yours is missing.
 Post subject: What year?
PostPosted: Thu Aug 26, 2004 8:17 pm
What year box/car?
Just curious I might have a spare you could have in 'the shed'...
PostPosted: Thu Aug 26, 2004 9:27 pm
Uh-oh, not "The Shed"! :shock: :wink:
PostPosted: Fri Aug 27, 2004 7:26 am
There is also an o-ring seal under that cover (two really, one for the cover and one for the screw), but the cover must be removed to access the one for the screw, if I remember correctly.
D/W
If it ain't broke, fix it!
 Post subject: The shed
PostPosted: Fri Aug 27, 2004 8:48 am
I'm with Eric,
Why is he going in the shed?!!!! Doesn't he hear the scary MUSIC!!!! :shock:
:lol: :lol: :roll:
 Post subject: Fixed
PostPosted: Tue Aug 31, 2004 9:13 am
Thanks guys. I put an extra rubber o-ring under the nut and now have no more leaks. I was just worried that I would loosen something and parts would fly everywhere.
Tom
