It is currently Sat Aug 23, 2025 8:20 am
PostPosted: Tue May 13, 2025 4:46 pm
Car Model: Dodge Motor Home (413 I/C), did own 1968 300 2D FB
By proposing to take 2 slant sixes, flip them back-to-back and making a 450 CID V-12?
I've been pondering this thought for a very long time.
Now before everybunny rants at me how that can't be done, I do not actually mean to destroy 2 perfectly good slant six blocks.
I would scan a block, make a CAD model that also incorporated all of the necessary changes [because, obviously flipping a block backward simply could never work anyhow], so that it could be bolted up to the same 727 or 4 speed bellhousings as any big block MOPAR would use, and it would, by default, have 2 separate cam shafts, but also, I would build some matching hemispherical combustion heads [because there ACTUALLY WAS ONE such hemi-[vertical]-six made by Chrysler at on point, as an experimental motor], and make an advanced alloy casting, including cross bolting.
The really wide mains, with enough extra webbing material, and a custom forged 12 cylinder based crank could really be a lot of fun.
Also, with HEMI heads, it would be a cross-flow head with the intake in the middle and the exhausts on each side.
I'd begin with a 450 CID base model, and gradually engineer it up to at least 660 CID [kinda like a 440, only with a 50% more cylinders], possibly take it all the way to 1200 CID...
Might even make an aluminum block version with aluminum heads and intake...with a blower-ready adapter...
I wonder if people would like it, or hate it... ~( ,m,)~
PostPosted: Tue May 13, 2025 5:42 pm
If you have the pocket change, go for it!
PostPosted: Wed May 14, 2025 3:28 am
If you are going to go to those extreams, why not go further? Legthen the block(s), use bigger bore/bore centers (allows bigger valves/ports), shorten stroke (more rpm). Or buy something like this
https://www.sonnysracingengines.com/eng ... gas-engine
It would probably be cheaper
PostPosted: Wed May 14, 2025 8:54 am
Or, y'know, instead of all that heavy-duty, high-dollar ironmongery, you could…oh, gosh, just blue-skying here, just spitballing…go troll somewhere else on the internet, child. :roll:
