It is currently Thu Aug 27, 2026 6:03 am
Post new topic  Reply to topic  [ 129 posts ]  Go to page Previous 1 2 3 4 5 69 Next
 Post subject: Re: Volare project
PostPosted: Thu May 22, 2025 9:42 am
Thanks Dennis!
'78 Volare 225
'67 Charger 318
PostPosted: Sun May 25, 2025 6:20 am
Torque converter bolts are out, as of yesterday.
Getting closer!
'78 Volare 225
'67 Charger 318
PostPosted: Sun May 25, 2025 5:54 pm
I started on the engine to transmission bolts this afternoon, I've removed 4 of them so far.
So how many of them are there?
'78 Volare 225
'67 Charger 318
PostPosted: Mon May 26, 2025 6:56 am
All of them! :D :D
One large one on each side at the bottom. 4 smaller ones between them.
PostPosted: Mon May 26, 2025 9:35 am
All of them! :D :D
2 bottom ones take a 5/8th wrench, the other 4 are 9/16th. One is in the front by the starter mount, the other 3 are in the backside.
PostPosted: Mon May 26, 2025 2:39 pm
Thanks Rick, thanks Dennis!
'78 Volare 225
'67 Charger 318
PostPosted: Mon May 26, 2025 6:18 pm
Ok, I've removed 5 of them. The 6th one is the bolt holding on the tranny dipstick tube. Its in a really challenging spot.
I managed to turn it a few times, very small increments though.
Any suggestions?
Maybe drilling a hole in the firewall to where I can get a socket and ratchet combo on it?
No really...
'78 Volare 225
'67 Charger 318
PostPosted: Tue May 27, 2025 3:42 am
Car Model: 78 aspen
wes, universal socket and a long extension.
since you have it broken free, drop to 1/4 drive. (at least right up at the bell housing)
when i am doing bell housing bolts i am usually using a 3' extension.
but then i do it for a living so i have all kinds of cool tools.
PostPosted: Tue May 27, 2025 3:45 am
A couple extensions and a universal will work. It may be pinched a bit if all the other bolts are out.
PostPosted: Tue May 27, 2025 9:04 am
I have a cheap E-Bay 24" extension and flex socket just for that bolt. Makes life a lot easier.
PostPosted: Sat May 31, 2025 1:23 pm
Ok, I got that bolt out.
The motor mount bolts are also loose.
I just have to support the tranny, but I'm not too sure about my cheap little floor jack, so I have to figure out an alternative.
Getting closer!
'78 Volare 225
'67 Charger 318
PostPosted: Sat May 31, 2025 6:49 pm
I started to pull the engine, but then I stopped.
My concern is that I won't be able to raise the engine high enough to get it out of the engine bay.
I'm thinking I should get some help with this, I'll see if a buddy of mine can come help.
So close...
'78 Volare 225
'67 Charger 318
PostPosted: Sun Jun 01, 2025 3:17 pm
Okay, today I did it.
The original slant six is out of the engine bay.
Hooboy, that was like work.
I needed more plywood for the floor of my storage space, but I got it out.
I planned to put the replacement slant in right after, but I've run out of steam for now.
So another baby step forward.
'78 Volare 225
'67 Charger 318
PostPosted: Sat Jun 14, 2025 7:29 pm
Ok, the replacement slant six is on the engine hoist, ready to be put in.
Should I remove the trans, or just drop the engine in?
What do I need to be careful of when installing the engine?
'78 Volare 225
'67 Charger 318
PostPosted: Sat Jun 14, 2025 8:52 pm
If the trans is in place i would just drop in the engine. Go slow, keep everything clear. Install the oil pump NOW since you have to jack the motor up to install it in an F body. Easier to install the manifolds now, too.
