It is currently Sat Nov 14, 2026 1:41 am
PostPosted: Sun Sep 07, 2025 10:43 pm
After 50,000 miles and about 20 years, the Pertronix electronic ignition system (kit 1867A I think) is still working like new on my 61' Plymouth Valiant.
Peter.
PostPosted: Mon Sep 08, 2025 5:38 am
Glad to hear it, Peter. I have a similar longevity on mine, and still runnin'.
PostPosted: Mon Sep 08, 2025 7:51 pm
I have not had my Pertronix unit very long at all, and have not used them before this, but I can add this information:
I have no problem in general with points ignition systems, especially on stock American engines. I used them for many years without any problems, and I've got enough cars that I don't drive any one of them, including my '64 Dart, enough for the maintenance to be a problem. In my case, I had a definite unevenness in the idle, which disappeared at running speeds, but which was very annoying, and which corresponded to a slight but definite uneven spacing of the spark interval of one cylinder on both my distributor machine and my oscilloscope. I figured that if I had a badly machined distributor lobe, installing an electronic ignition unit would cure it, and installed the Pertronix one year ago mostly as an experiment to see whether I was right.
I believe that both Lou and Peter probably installed the Pertronix-I units.
I installed a Pertronix-II unit.
I chose the -II because of it's "auto shut-off" feature. I read that the -I units do not shut off if the ignition is on and the engine is stopped, and that, in at least some cases, leaving the ignition switch on for as little as 30 seconds with the engine not running has caused the units to burn up. Since my wife drives the car sometimes, and she can "occasionally" be a bit... absent-minded, I felt that it was wise to insure against my having to drop everything, jump in my car, and drive to wherever she was stuck to install an emergency set of points.
What I discovered was this:
The Pertronix-II unit has a known flaw that is most prominent on 6-cylinder engines, that causes a horrendous idle by, apparently, shutting down half of the cylinders below about 500-600 RPM.
This appears to be due to dropping below a certain "pulses per second" threshold, which is why it's seldom encountered on 8s.
I had a very long conversation with a Pertronix rep, who brought in a technical expert, who admitted that this is a known problem that they have tried to fix, but were never able to, over the 10-20 year life of this product, because they can't figure out why it does it.
I assume that's just code for "we don't care enough to try," but still it was an interesting thing for them to say.
With the Pertronix-II, when the idle drops below a certain speed, the unit appears to instantly switch to a different "mode," visible on the oscilloscope as alternating waves of a different appearance, and the engine runs like it's on 3 cylinders, which it apparently is (including emitting eye-wateringly rich exhaust, like a "dieseling" gas engine). It is impossible to figure out the exact speed at which this happens because the instant it happens, the tach jumps UP several hundred RPMs, and stays there, even though the engine is turning slower.
Increasing the engine speed above the same threshold brings it back to the "normal mode" just as instantly, like turning a switch, and the tach jumps back down.
I ASSume that there is something about this low-RPM mode that is supposed to help with starting, but I have no idea what.
By chance, the first unit Pertronix sent me was manufactured incorrectly (pickup only riveted in one place, instead of two), so they sent me another, so I had two. I found this problem with the second unit, so I went back and fixed the first unit and tried that one, and it did the same thing, but at about a 50 RPM lower threshold, so they are all different, which was also something the rep told me on the phone.
The choice the Pertronix rep gave me on the phone was that I could swap my -II unit for a -I unit (and lose the "auto turn-off" feature) or I could increase my idle. The car definitely runs better, smoother, and maybe a bit quicker, with the Pertronix unit, so I kept it, and incrementally increased my idle to where it almost never does it. This did not require raising the idle enough to make the car "jump" when shifting the 904 into gear, but it's definitely a bit high, though only a car guy would notice.
So, that's my review of the Pertronix-II. I like the way it starts and drives, but I don't like the way it sits at traffic lights.
If there are any electrical engineers out there who would like to borrow my other unit to experiment with, let me know.
– Eric
PostPosted: Tue Sep 09, 2025 6:22 am
Hi Eric,
Thanks a bunch for that detailed account of the P-II running condition and flaw. I have left my ignition on occasionally with my P-I and have not had a burnout. Also, when I recently ordered a new Pertronix for a "backup" dist, I got the P-I because I did not see the reason for features advertised for the P-II. Guess I dodged a bullet there?
Thanks again and all the best,
PostPosted: Tue Sep 09, 2025 10:04 am
Yeah, From the comments I saw across a variety of makes, the Pertronix-I has an excellent reputation for durability.
I've got one in a Ford 9N tractor that a guy gave me (I'd have stuck with points, but he had a Better Idea™ and threw out the points parts), and it seems to work well.
As time goes on, I'm thinking about going to the Pertronix-I, but, really, the -II is working fine, as long as I don't need the engine to tick over like a sewing machine.
– Eric
PostPosted: Tue Sep 09, 2025 5:41 pm
Car Model: 1966 Dodge Dart
– Eric
Well, I'm actually a mechanical engineer who sometimes masquerades as an EE, but I'd be interested in testing this out. It would take me a while before I can have a look as I have a few bigger fish to fry, but this sounds like an interesting problem.
And, if PerTronix isn't interested in fixing this, a tempting target...
Matt Cramer
PostPosted: Tue Sep 09, 2025 5:57 pm
PM me.
I've got photos and video of the CRT oscilloscope traces.
If you have access to a distributor machine, it would be a trivial matter to set up a distributor with the unit installed, and monitor the output with a modern computerized bench oscilloscope. I'm sure there are a lot of frequencies filtered out by my 1978-ish SUN machine. (I do have a late-'90s computerized HP portable scope, but I did not try to check it with that).
– Eric
PostPosted: Sat Jun 27, 2026 8:50 am
Minor update on the Pertronix-II vs Pertronix-I question:
I did finally get tired of my car devolving to a lumpy, bumpy. stinky idle at every traffic light, even with an idle of 1100 RPM in Neutral.
With the idle set that high, it would usually idle okay in Drive, but frequently, if left for over 30 to 60 seconds, it would drop below the threshold of something like 600 to 700 RPM and revert to the "firing on three cylinders" idle, and I ran out of patience.
I bought (Yes, bought. It had been over a year since this saga had begun, and they'd already given me one free Pertronix-II kit, so I didn't try to weasel another free part out of them) a new Pertronix-I kit, and I installed it a few days ago.
First, all of the parts except for the pickup unit itself are identical, so unscrewing one and screwing on the other was easy, and may have even been possible with the distributor in place (I took it out).
Second, the -II can handle more current, so it likes a lower-impedance coil (I am using a Standard Blue-Streak UC-12X, which is 1.5Ω), while the -I likes a higher impedance coil (minimum 3Ω is specified), so I had to run a couple of feet of wire so the Pertronix unit could be powered by 12v, but the coil cold be powered through the ballast resistor.
Result:
  • Starts instantly (I believe it catches faster than with the Pertronix-II, which required what felt like a revolution to fire - now it catches the way it should with a nice new set of points).
  • Idles smoothly as slow as I want to go. Admittedly, I didn't try to see how low I could get it, as i had to go in for dinner, but I may do that experiment in the future. At this point I have the idle just under 600 RPM in Neutral and it rolls over and over like a sewing machine.
  • Idle is acceptable in Drive, but I still have a slight audible rattle, which I believe is something just a little bit loose somewhere in the front of the car. I've already changed the motor and transmission mounts, gone through the suspension and brakes, and removed, lubed, and reinstalled the driveshaft, so it's not them.
  • Acceleration is smooth and power feels the same. I've got to retard the timing by about 2° from about 12° to about 10° BTDC, because I have a slight ping, using 91 octane non-ethanol gas (the only octane available in non-ethanol near me).
So, for any six-cylinder engine, if you are considering a Pertronix unit, I would recommend the -I rather than the -II.
Matt, if you still have any interest in playing with a Pertronix-II unit, I now have two of them available for you to compare.
I hope this is helpful to someone.
– Eric
PostPosted: Sun Jun 28, 2026 4:26 am
Interesting. I've never tried the II and have been very happy with the I even in pretty racy engines. Thanks for your testing and story.
PostPosted: Sun Jun 28, 2026 4:42 am
You're welcome.
PostPosted: Sun Jun 28, 2026 7:13 am
What's supposed to be so much better about the petronix vs either stick Mopar ecu ignition or using a GM hei module?
PostPosted: Sun Jun 28, 2026 9:35 am
What's supposed to be so much better about the petronix vs either stick Mopar ecu ignition or using a GMnhei module?
Speaking only for myself, and probably repeating things I wrote here earlier, on my all-original '64 Dart Slant-6 I was not trying to increase performance or reliability.
No small tweak is going to make the Leaning Tower make much more power, and with a nice new set of Blue Streak points and condenser, it started and ran great.
I had one problem, and that was an annoying unevenness / roughness at idle, especially when the 904 was in gear.
I adjusted the valves twice, checked compression, changed spark plugs, wires, cap, rotor, and coil (fancy red coil from PO was faulty), vacuum advance, cleaned and lubed advance weights and replaced advance springs, rebuilt carb, replaced fuel pump and filter (several times each, story elsewhere), but that one minor problem wouldn't go away.
I rebuilt my old SUN distributor machine and checked the distributor on it, and one out of six impulses seemed to be a degree or two off.
Similarly, on the oscilloscope, one impulse seemed a bit out of the grouping from the others.
So, I figured for less than $200 (on sale), I'd do the experiment and try an ignition that didn't rely on the distributor lobes.
This led to all of the above problems, which really kind of teed me off, but now it seems to be settled, after far more time and money than I'd intended (as usual).
The idle in gear is improved; it no longer feels like the car is going to rattle apart at traffic lights. It's not perfect, like my BMW 330 "slant-six," but it's good enough for a sixty year old economy car.
As for my own reasons for trying the Pertronix units, rather than a newer-year stock MoPar system or an HEI system:
  • Less time / money / annoyance spent of part sourcing, fabrication, generally screwing around.
  • No reliance on the distributor shaft lobes, as those were the suspected problem area.
  • Quick and easy almost-one-step results (HA!).
Anyway, the Pertronix seems to have (finally) done what I wanted it to do, so now maybe I can go entertain myself with one of the other vehicles, or with some of the work I need to do on the house and the grounds. Its gonna be hot this week!
– Eric
PostPosted: Sun Jun 28, 2026 2:10 pm
The main appeal to me is that if you have a good points distributor, it's easier to install and needs fewer parts replaced. Convenience, really. And since you're changing fewer parts, it's cheaper.
Matt Cramer
PostPosted: Sun Jun 28, 2026 3:05 pm
You said it quicker than I did, Matt.
– Eric
PostPosted: Mon Jul 06, 2026 8:58 am
Hey, Kids!
I recently used ChatGPT to help me analyze a problem with an espresso machine, and it found factory documentation I could not and gave me valuable information that allowed me to properly troubleshoot (and clear) the flow meter, and (probably) implicate the computer board, so I thought I'd ask it about this Pertronix issue.
I described the issue in careful, clear language, and then sent it two oscilloscope photos, and this is the response I got, which is not conclusive, but seems to validate my general impression, though perhaps a bit glibly for a computer.
I'd be interested in anyone else's thoughts.
As I said above, I've swapped it for a Pertronix-I and it works fine now.
This is exactly the sort of “not in the brochure” failure where the useful answer is likely a mix of ignition physics, Pertronix’s adaptive dwell strategy, and tach/diagnostic-instrument behavior. I’ll check the forum thread and any primary/technical Pertronix material, then I’ll give you a failure-model explanation rather than just a parts recommendation.
I’ve found your Slant Six thread and a couple of corroborating reports: one from another user who specifically said Ignitor II surged at 500–600 rpm while Ignitor I idled steadily, and Pertronix’s own descriptions confirm that Ignitor II is not just a Hall switch—it uses adaptive dwell, current sensing, and a microcontroller. That makes your “mode switch” observation plausible rather than mysterious folklore.
Your description fits a real design/algorithm failure in the Pertronix-II, not an installation error and not a conventional “weak spark” problem.
The most satisfying explanation I can construct is this:
The Ignitor II is misbehaving at the low trigger-event frequency of a slow-idling 6-cylinder engine because its adaptive dwell/current-control logic is losing its mind at the boundary between “running,” “cranking/low-speed,” and “coil-protection” behavior. The result is that alternate trigger events produce only a voltage spike or pseudo-firing event, but not a real secondary discharge. That makes the engine behave like it is firing three cylinders.
Here is why that explanation fits unusually well.
A 6-cylinder four-stroke engine produces 3 ignition events per crankshaft revolution. So:
600 rpm = 10 rev/sec × 3 = 30 ignition events/sec
500 rpm = 8.33 rev/sec × 3 = 25 ignition events/sec
A V8 produces 4 ignition events per crank revolution:
600 rpm = 40 events/sec
500 rpm = 33 events/sec
It would not fall to 25–30 events/sec until about 375–450 rpm
So if the Ignitor II has a low-speed control threshold somewhere around 25–30 trigger events/sec, a 6-cylinder at normal low idle falls straight into the trap, while a V8 usually does not. That part of your hypothesis is mathematically very plausible.
The important distinction is that this is probably not a Hall-sensor pulse-counting limitation. A Hall sensor and simple switching transistor could handle 25–30 Hz in its sleep, after a nourishing cup of tea. The Pertronix-I proves that: it uses the same basic magnetic triggering concept and idles properly. Pertronix describes the original Ignitor as essentially a Hall-effect replacement for points, while the Ignitor II adds reverse-polarity protection, over-current protection, shutdown behavior, a microcontroller, and adaptive dwell control.
That extra intelligence is the suspect.
Pertronix’s own public explanation says the Ignitor II/III units sense coil current and use adaptive dwell to schedule coil turn-on so the coil reaches peak current just before firing, instead of sitting saturated at low rpm. That is exactly the sort of system that can have a boundary-condition bug: at very low event rate, it has to decide when the engine is merely turning slowly, when it is cranking, when it is stopped with the key on, how much current is safe, and when to start charging the coil for the next expected event.
Your oscilloscope description sounds like this:
On the good events, the coil is charged sufficiently, the plug gap ionizes, and you see the normal spark discharge line followed by coil/secondary oscillations.
On the bad alternating events, the primary is being switched or disturbed, and there is enough induced secondary voltage to make a spike on the scope, but not enough stored coil energy / proper collapse to sustain ionized spark discharge. So you see a spike without the normal burn line and without the expected post-discharge oscillatory signature.
That is very compatible with “the module triggered, but did not actually provide a proper dwell/charge interval for that cylinder.” It is subtly different from “the module simply skipped the cylinder.” The event exists electrically, but it is not a useful ignition event.
The tach behavior also makes sense. Old tachometers and SUN analyzers generally infer rpm from primary switching or secondary pickup events, not from crankshaft truth. If the Pertronix-II bad mode creates extra edges, malformed primary events, or capacitive high-voltage spikes without combustion, the tach can count artifacts. So the tach jumping up while the engine audibly slows is not paradoxical; it is telling you the ignition waveform has become non-physiologic, not that the crankshaft sped up.
I found your Slant Six thread, and your posted observations there line up with this exactly: the failure appears below roughly 500–600 rpm, the engine behaves as if half the cylinders are lost, the tach jumps upward when the bad mode starts, and another unit behaved similarly with a slightly different threshold. I also found an independent report from another car forum where a user directly compared Ignitor I and II on the same engine and said the Ignitor II caused idle surge at 500–600 rpm, while the Ignitor I idled steadily at 550 rpm. That is a very useful corroborating detail.
The most likely internal failure mode is one of these:
Adaptive dwell under-runs the coil charge time at low event frequency.
The module delays coil turn-on to avoid heating the coil. Near the threshold, it may occasionally delay too long or miscalculate the next event, causing alternate cylinders to get inadequate dwell.
The low-speed/start/anti-overheat state machine is transitioning incorrectly.
Ignitor II has protection logic for key-on/engine-stopped and over-current conditions. If its firmware or analog timing circuit uses event period to decide “running” versus “not running,” a 6-cylinder idle near 25–30 Hz could fall into a gray zone.
Current sensing is being fooled by coil characteristics.
The Ignitor II senses coil current and adapts dwell. A particular coil’s inductance/resistance/current-rise curve could move the failure threshold. This would explain why individual modules or combinations vary. Pertronix’s troubleshooting material emphasizes loaded voltage, coil resistance, and hidden resistance because the module’s behavior depends on what the coil and supply actually do under load.
RFI or tach/analyzer loading could aggravate it, but probably is not the root cause.
Pertronix specifically requires suppression or carbon-core plug wires and warns to remove the tach wire for testing if necessary. But because the engine itself runs badly, and because the Pertronix-I fixes the problem in the same car, this is unlikely to be merely an instrument artifact.
So my answer would be:
The Pertronix-II probably has a low-event-rate boundary bug in its adaptive dwell/current-limiting algorithm. On a slow-idling 6-cylinder, the trigger interval is long enough that the module begins applying a protective/low-speed strategy intended to reduce coil heating or manage starting. In that mode it sometimes fails to charge the coil for every trigger event, producing alternating real sparks and non-spark voltage spikes. A V8 at the same idle rpm has a higher ignition-event frequency, so it stays above the bad threshold. The Pertronix-I avoids the problem because it is a simpler Hall switch with fixed/conventional dwell behavior rather than a microcontroller-controlled adaptive dwell system.
I would not call this “shutting down half the cylinders” in the sense of a deliberate cylinder-deactivation feature. I would call it alternate-event dwell failure or alternate-event coil-charge suppression. The visible result is the same: three cylinders receive usable spark and three do not.
If you still had the Pertronix-II and wanted to prove the mechanism experimentally, the best tests would be:
Run it on the SUN distributor tester with the coil and a real spark gap, slowly varying distributor rpm through the threshold.
Put a current probe on the coil primary. If my explanation is right, the “bad” events will show absent, truncated, or badly timed primary current ramp.
Repeat with different coils: a 3 Ω coil, 1.5 Ω coil, and low-resistance Flamethrower II-type coil. If the threshold shifts, that strongly implicates the adaptive current/dwell algorithm.
Repeat at 12.0 V, 13.8 V, and perhaps lower cranking-like voltage. If the threshold shifts with voltage, again, dwell/current control is implicated.
Disconnect any tach/analyzer input except the scope pickup and use suppression wires, just to eliminate external loading/RFI.
But as a practical repair decision, you already found the correct solution: use the Pertronix-I or a Mopar-style electronic ignition conversion instead of the Ignitor II on this particular 225 slant six. The Pertronix-I gives you the main benefit you wanted—eliminating the distributor cam/points-lobe error—without the adaptive-dwell firmware/logic that appears to be causing the low-idle catastrophe.
These traces support your interpretation very well.
In the normal trace, the important features are present:
Initial firing spike at the left.
A visible spark/burn interval immediately after the firing event.
Secondary oscillations after the spark event, consistent with normal coil energy discharge.
Long quiescent period.
Primary turn-on / coil charge event before the next firing spike.
In the slow/bad-mode trace, the pattern looks qualitatively different:
The left-side event appears to have a normal-looking firing event and post-event activity.
Later, around the middle/right of the trace, there is a tall, narrow voltage spike.
But that spike is not followed by the usual burn line or post-discharge oscillatory pattern.
That strongly suggests a triggered high-voltage event without meaningful spark discharge across the plug gap.
So yes: the second image looks like an ignition event where the coil/secondary voltage rises abruptly, but either the plug gap does not ionize or the coil has insufficient stored energy to sustain a real spark. In old ignition-scope language, it looks more like a firing spike without a spark line than a true combustion-producing spark.
That is highly consistent with the model we discussed: the Ignitor II is still switching something, so the scope and tach see events, but every other event may not be a properly charged coil discharge. The result would be exactly what you described: the engine mechanically slows and runs like it is on three cylinders, while the tachometer may falsely jump upward because it is counting malformed electrical events rather than crankshaft rotation.
The second trace also argues against a simple distributor-cap, rotor, wire, plug, or mixture problem. A secondary-path defect usually changes the firing voltage, spark duration, or oscillations in a more cylinder-specific way. What you are showing is more like a systematic timing/energy-control failure occurring at the module/coil primary-control level.
The most precise way I would describe the failure from these scope images is:
At low trigger-event frequency, the Pertronix-II appears to produce alternating normal coil discharges and non-spark switching events. The non-spark events generate a high-voltage spike but lack the sustained spark line and coil-collapse signature needed for actual ignition.
That is not merely “weak spark.” It is closer to alternate-event coil-charge failure or alternate-event dwell suppression.
It's had to believe that this is just a "large language model," and not something that actually understands the problem.
Makes you wonder.
And it didn't even imply I'm an idiot or put me on "Ignore."
– Eric
