It is currently Tue Oct 13, 2026 3:48 pm
Post new topic  Reply to topic  [ 206 posts ]  Go to page Previous 1 … 10 11 12 13 14
PostPosted: Mon Oct 14, 2024 10:48 am
and yes,,,, I was laying sideways on the floor when I took these photos and that is why the pictures are the way they are.
I also took the same photos standing up with my feet on the floor and posted those a FABO and FB, so if you want to see the normal view, look over there.
PostPosted: Mon Oct 14, 2024 11:21 am
Herb Mccandless will be proud. :mrgreen:
Looks like a fun project John.
PostPosted: Fri Oct 25, 2024 3:42 pm
A bit of progress concerning the 4 speed swap in the 68 Barracuda.
Working with Brewers I have new Hurst shifter, shift rods, the 1-2 and reverse are Mopar A body 4 speed rods the 3-4 is an OD rod, also put in new bushings and clips. I plan to have the transmission gone through internally prior to the install.
Interesting item on this transmission is, the S/N pad has the transmission identified as a 3 speed 230 unit. Just another day in the Mopar assembly plant. Also the speedometer gear and housing is a different design that what I have seem previously.
don't know why the photos I post here on .org randomly change orientation. The S/N pad photo is the same orientation as the other 2 photos on my phone-computer-FABO,,, post it here and it flips over 180 degrees,,,,,
PostPosted: Fri Oct 25, 2024 4:33 pm
That plastic gear / housing arrangement is in most/ all FJM body cars. I am not sure on the change over year.
PostPosted: Mon Sep 29, 2025 4:27 pm
A project completed on the 68 Barracuda
I had installed roller rockers and B3 valve train stands, that raised the rockers enough to require modifications to the stock valve cover.
One of the mods was to remove the internal valve cover baffles. I installed a Moroso PCV line catch can and that was effective, but the catch can would fill after a hundred miles of easy driving.
To be able to re install internal valve cover baffles I needed to raise the valve cover. That was accomplished with the hydraulic head valve cover spacer mentioned in the CAD Cam thread.
I used a standard Fel Pro cork-rubber gasket on both sides of the spacer and substituted in studs in place of the standard valve cover bolts to keep things aligned during assembly.
Verified the under valve cover clearance with rolls of clay.
The results are all good. There is absolutely no oil carry over into the Moroso catch can after miles of spirited driving.
PostPosted: Tue Sep 30, 2025 7:36 am
Nice work, John. Thanks for sharing. Glad you are enjoyin g the car.
PostPosted: Mon Oct 06, 2025 10:02 am
Whoo hoo.
Glad my engineering is working for your project.
Enjoy the car!
PostPosted: Mon Oct 06, 2025 6:05 pm
Lou - Greg thanks!
PostPosted: Mon Oct 06, 2025 6:21 pm
One more project for the 68B is to make it a 4 speed car.
When I built the car I put in a set of manual transmission-clutch pedals, a 4 speed hump on the floor and matching interior carpet, so that much is done.
Also years ago, working with Wayne V I had a slant to a small block adapter plate made.
Taking this one step at a time I modified the 130 tooth v8 flywheel to match the slant six crank shaft hub.
I threaded the existing v8 off set hole flywheel mounting hole, plugged that with a piece of all thread then redrilled the mounting hole in the correct slant six location.
Next I mounted the adapter plate-flywheel and QT bell housing and starter to a spare slant six engine that I have in the garage check to the gear mesh of the starter to the flywheel.
Using jumper cables I engaged the starter. About a 50% gear mesh, that should be OK.
The next steps will be taking the long tube Hooker headers off the slant that is in the 68 Barracuda mounting those to the spare engine to see how those headers will fit with a low starter mount.
This project will be something that I work on from time to time in the remaining days of 2025 with a completion some time in 2026.
I have no idea why some of the photos post sideways,,,,,
PostPosted: Tue Oct 07, 2025 2:13 am
Looks like great fun, John. We should try to meet at an AutoX sometime, maybe with Greg too. I am working my 62 Valiant toward being a more potent AutoX performer, and it already handles, stops, accelerates quite well.
Wayne called me recently and we talked about his engine project. Sounds like he is making steady progress.
Best wishes,
PostPosted: Wed Oct 08, 2025 5:29 pm
Lou-Greg Thanks
Meeting up for an Autocross Event is a Great Idea, in addition I am certainly not opposed to doing a slant six drag race event in the future.
At this point in time, I cannot make a firm commitment as to when. Life is good and I have been using these retirement years to do a lot.
I am in a very active pickleball group locally, and I play extremely competitive PB, about 3 hours a day 5 to 6 days a week. Put that with family and spousal commitments and life is full and active.
An addition is I do really enjoy the garage time and that is why I have kept the 68B and have projects planned.
Just this evening I was on the McMaster-Carr site looking at hardware to make this a833 to a v8 bell to a slant six possible. The engineering work is also a part of who I am.
The things we get satisfaction from define us and our friends. And I like my slant six friends,
