It is currently Fri Nov 13, 2026 9:54 pm
PostPosted: Wed Nov 12, 2025 4:39 pm
Since my original install of MSII (2008) it works well for my needs (batch fired multi-port injection) and full (single) coil control by the MS II via a OE type Slant 6 Distributor.
I updated the firmware from 2008 to ~2019 I think about 6 years ago. The firmware update added so much more functionality in tuner studio / MSII.
The CL Idle control works well except for some hunting issues on a ~ medium warm restart.. It will hunt and oscillate for a few seconds; however if i give it just a bit foot throttle angle, the hunting vanishes when CL Idle shuts off.
What I am asking here is without blindly playing with the P, I, D settings, (as every other idle situation is very good - not 2020 OE new car good, but good enough for me) how to I tune out the "hunt/oscillate" in the P, I, D Settings?
Thank you,
PostPosted: Wed Nov 12, 2025 5:01 pm
Replace fuel injection with BBD. :mrgreen:
PostPosted: Wed Nov 12, 2025 6:18 pm
I did it the other way 'round sir!
This is the fuel injection sub-forum 'ya know!
PostPosted: Fri Nov 14, 2025 4:01 am
I knew I got lost somehow! :D
PostPosted: Sun Nov 16, 2025 1:15 pm
Greg,
Check the ignition advance table to verify that the idle oscillation is not due to the ignition advance table adding advance and causing the RPM run up, having the rpm too high the ecm cuts fuel dragging the rpm down, the ignition then advanced causing the oscillation.
I too have my slant powered ms controlled 68 Barracuda starting and driving like a modern car.
Just turn the key, no throttle added and it starts, idles down as it warms.
I ‘messed’ with the PID to get where I am.
And messed with is basically what I did.
1) made one adjustment at a time and then took the time to determine if there was a difference
2) kept good notes on what was changed so I could go back and not run myself in circles.
I don’t currently have access to my notes or the car so I can’t be more exact on what I did.
There are You Tube videos that provide guidance of what each element of PID does that were helpful.
PostPosted: Mon Nov 17, 2025 4:45 am
I am pretty sure the Ign advance is not the issue, but a good thought to check. I will have to do that and keep the Ign advance gauge open when I observe hunting, which is not often. Sometimes it starts and idles down just superb.
I have seen some videos, but I was looking for specific guidance on how it applies to the CL Loop. There is also a slider in the settings window that seems to scale all of the settings for the PID CL Idle.
I guess I wanted a more pinpointed approach instead of fussing and doing trial and error testing, as I know how to do that.
PostPosted: Mon Nov 17, 2025 5:58 am
You could try moving the slider to the "faster" or "higher gain" setting and see if that helps. Often when a feedback system oscillates, it is because the feedback timing (time constant) is too slow for to compensate for the effect that is causing the changes to the system.
PostPosted: Mon Nov 17, 2025 6:31 am
I think the slider Gain is for all 3 variables, then there is an individual percentage gain for P, I, D.
I love pictures. Here is one:
ImagePID Tuner Studio by Hyperpack, on Flickr
PostPosted: Mon Nov 17, 2025 10:03 am
This short video discusses the I term in the PID,
the I is used to control over or under corrections to target
https://www.youtube.com/watch?v=i3dCYL-Dmkg
Also note the table shown in the video has corrections in the fractions of a percent.
PostPosted: Mon Nov 17, 2025 10:12 am
Thank you, John, I will study.
G
PostPosted: Mon Nov 17, 2025 10:35 am
and this video goes into more detail about PID
it deals with PID and EGO control, but the PID function is the same with idle control
https://www.youtube.com/watch?v=B4glNBZQiGc
PostPosted: Thu Nov 20, 2025 5:31 pm
Car Model: 1966 Dodge Dart
Can you post a log of the oscillation and your tune? Sometimes the oscillations aren't even IAC related.
Matt Cramer
PostPosted: Fri Nov 21, 2025 5:40 am
Can you post a log of the oscillation and your tune? Sometimes the oscillations aren't even IAC-related.
Here is a link to my current .MSQ File. I have no Logs, but it does not always oscillate, just on Hot / medium-hot restarts.. I did futz with some settings, but I have not yet solved it completely. I will see if I can get a log when it does this.
I was doing some running around / errands, stopping and parking often yesterday; it was very oscillatory on a med-hot restart to the point it stalled twice on me during that restart. I am beginning to think it might be a heat soak issue in the fuel rail? It is fantastic on hot and cold starts and on quick restarts after a shut-off.
Thank you, Greg
PostPosted: Fri Nov 21, 2025 7:01 am
I have always had pretty substantial heat soak on the turbo Dart (esp when really hot on hot days), especially with the Dutra Duals before the supercharger and headers.
PostPosted: Mon Nov 24, 2025 8:22 am
I'll need a log of the oscillation to see how that tune is working in the real world, but my prime suspect right now is that abrupt jump in the fuel table between 44 and 48 kPa. Also, that's not very much timing at full throttle.
Matt Cramer
