It is currently Sun Aug 16, 2026 1:31 am
PostPosted: Sat Nov 22, 2025 12:52 am
Car Model: Lonestar
Where I live, /6 engines are a bit rare as old Mopars were shred due to rusting. My knowledge and interest in the slant 6 was because my 1956 Lone Star Cruiseliner 2 boat came with one, but needed work. Not many were made with the Slant 6 225 inboard/outboard setup. The boat is big and heavy. So I had thought about changing it out for a bigger engine, but decided to squeak out as much as I could from the old Slanty. But the project gets sidelined a lot. And now I am at a cross roads. Continue? Sell it all? Just get it back together and enjoy it?
Now then, I have before me an opportunity to get a running 1970 198 out of a Duster. I was thinking of using the rods in my 225. But maybe just rebuild it stock.
If I do get the engine, what is the going rate for the 198 rods, If I were to just part the engine out? What about the Crank?
Thanks all for your feedback. Fyi, I am in Central Canada.
Brian.
PostPosted: Sat Nov 22, 2025 4:01 am
Hi Brian,
Thanks for posting and glad Slants are on your mind. The boat sounds cool, and I'm sure you can pep up the Slant if you put in some time and effort (and $). How good are you with basic mechanics and such? Do you have a good/reliable engine machine shop near you? Doing some mild "bowl porting" of the head can get you substantial HP and tq gains without a ton of work. I am guessing this is the "tilted flat" engine so your intake and exhaust manifold and carb options are either limited or totally fixed.
It's not clear how much (if any) 198 rods help you, but they have been used by many. Probably a set of core rods is worth $200-400/set depending on the buyer. Crank is not worth much, but you can always post them here and see. They are certainly very rare these days, but Slant folks are also cheap... ;) If you use the 198 rods, you will need different pistons than stock (with lower compression height - around 1.6" instead of the stock 225 at 1.74". Unless you are doing a high compression, high HP engine, the 198 rods are really not worth the trouble and expense.
Happy to discuss more parts of your projects as you think through things...
Lou Madsen
PostPosted: Sat Nov 22, 2025 10:10 am
Site Admin
Yes and no. Substantial gains can be had when coupled with other modifications. When taken in concert, the torque curve can be widened and extended with long rods, but not inexpensively. There are other places, like Lou suggests where your returns may be greater. I don't know how much wiggle room you have with your out-drive to take advantage, such as carrying more prop. Boats are a different animal. Pushing the limits where it isn't as simple as parking over the fog line, and calling triple-A isn't an attractive option to me. I like to row, but paddling a power boat isn't on the top of my favs.
There are applications where the 198 parts can be used to good effect. The crank can be used for a 210 low deck but that isn't going to be appropriate for a boat, unless the out-drive can be modified to take advantage of higher revs, the rods are a healthy part of a racing engine, and could be used with a selection of parts to make either economy or power. Just depends on what you are trying to accomplish.
Last I remember when Doc was doing mad-scientist stuff, he was building a high deck with a 170 crank and long rods for a high fuel efficiency commuter. I don't know if that survived the fire. If I remember right, the rods were a lot longer than 7.005" to get zero-deck. Be great to hear from him again!
I ran a long rod with a stroker crank, and it made for an over-the-top torque curve. Lots of machine work, and clearance work for 250 CI and 10.8:1 I put $10k into that engine. I don't know that I would want to be at the mercy of river current depending on that engine. It ran a quarter mile at a time, and runs to this day. There were "idiosyncrasies" that would made it unsuitable for cruising. It still bumped the fuel economy up just over 20mpg so long as the revs stayed down. ~2500 which was stall, so it made heat in the trans.
Doc ran a stroker that would tow and cruise in his wagon. He used to tow his toad all over the west coast with it. But.. 225 rods. There are some benefits for dwell time the better rod ratio 7.005" rods provide, but that is clearly debatable as you talk to other camps.
If K1's had been available back when I built my long rod, I would have used them. Not that the stock 198 rods had any particular weakness, but availability was better with the K1's for the better part of the last two decades. Finding serviceable 198 rods is like finding hens-teeth, so don't damage them. The ones I have were machined and lighened, with the small end resized to fit smaller pins in order to play nicely with my pistons of choice. One-offs. I have another set of 198 rods in the wings, and a new set of K-1's I bought when they became available.
5 cents, as pennies are obsolete...
CJ
PostPosted: Sat Nov 22, 2025 10:30 am
Car Model: Lonestar
Would a 198 have a different cam in it when compared to a 225? Would there be any changes there if I used that, probably stock, bump stick, when compared to lets say the 80s dodge truck or possibly the unknown one in the boat engine? I am curious but would have to take some measurements off of that one to compare specs.
I think I have concluded, at least for myself, that I am not going to long rod this project, based on input here, but I am not sure I want to even invest (time and $) on saving these 198 rods from the shredder. It sounds like there are aftermarket K1's? for such a build now for those inclined to put the $$$$ into an engine.
PostPosted: Sat Nov 22, 2025 11:55 am
Site Admin
No difference in the cam, head, or block. There was a guy not long ago that was looking for 198 bits, and there will be again, I'm sure.
If you decide to work the chambers and ports, read up. There is water very close to the ports. Doc posted some photos showing how close. Going to oversize valves doesn't require sizing up on the seats. You can easily hit water cutting for a larger seat, and it won't matter for the valve sizes that won't shroud on the bore. There are options like Chevy small block valves, and Ford 300 valves, though you may find you have to turn the Ford valves down a bit for clearance. I turned mine down, and back cut them. Oversize valves generally won't give big gains until you are .060 over with the bore. If you choose to use larger valves, make sure to check chamber alignment of the bores. You risk tagging the deck with a valve, especially when cutting the deck and/or head for compression. Generally speaking, there aren't a lot of gains in over-bores, as it doesn't add many cubes. 0.100" over is a 238. The only way to make a big difference in cubes is stroking, but the 225 is already well under-square, so Piston to wall speeds, and reciprocating forces are not ideal for high rpm operation with a stroke. If the operating envelope is kept in check, that can be OK. The head won't flow well enough to take advantage of higher revs anyway. A stock 225 can survive at 5500 as long as it's put together right. Some folks run higher, but tend to find weaknesses rather quickly. A 225 at 6000rpm is a time bomb. 7000 rpm is asking for trouble right away with all but the top drawer builds. With a stroker like mine, you can hear the engine getting unhappy anytime it's over 5000 rpm. At 5500 it makes unpleasant noises. It's also a bit pricey to stroke the slant substantially if your not going for a smaller rod journal. I had my crank welded up to get back to the standard rod journal with a 4.475" stroke. I don't know what Doc did with his 4.500" stroke crank. With four mains, even the forged crank is going to flex at higher revs, so surface hardening or coatings aren't going to live long. I didn't bother. The bearing area is huge, so as long as your oil and filter habits are good, it won't make much difference in life expectancy. Once up above 4000 rpm operating ranges, oil pump drive gears become "a thing." There's plenty to read on this forum about ways to mitigate oil pump gear failures. At lower rpm, aeration and cam walk are lesser. With a boat, higher rpm may not be desired. Of course if your going with Stainless or surface piercing drives, cavitation might be less an issue.
Compression, careful head work, cam selection and ignition system would be what I would concentrate on. All selected for the desired operating envelope, and fuel grade. Bigger is often not better.
Enjoy the journey!
CJ
PostPosted: Sun Nov 23, 2025 12:54 pm
Sounds like a keen boat, but…1956, you say? If that's the right build date, then none of them was built with a Chrysler Slant-6. That engine didn't exist until late 1959, and wasn't marinized until 1964.
PostPosted: Sun Nov 23, 2025 1:48 pm
I'm not going back in my current/6 anytime soon but I sure wish someone had a set of 198 rods they didn't know what to do with when I was in early stages of that build
PostPosted: Tue Nov 25, 2025 5:27 pm
Site Admin
One of the things I will point out about 198 rods...
They are used. They haven't been produced for a long time.
They may have been involved in a rebuild at some point. Maybe by a competent machinist, maybe not.
Resizing. If the rods didn't need it, they generally got it anyway. It was a billable line-item. If it was done by somebody competent, it may have been a minimal shave, if not, maybe a test to see how deep the new carbides would cut in order to impress friends, or piss off the shop owner with broken tooling. At a certain point, those rods will have been cut, ground, and machined back to service spec to meet the service limit.
There isn't enough material to make them "Forever Rods." I bought a set that had passed a point where serviceability was in question. Once done, it's junk.
I bought a good 'Virgin" set, I bought a set that hadn't been eligible to wear white for some time. The price was the same. One of those things was not like the other.
What does this all mean? Site unseen, I won't pay squat for a set. I need to see and measure them to know if they are car parts, or industrial art. I have a Con-Rod machine. I kinda know how it works.
For entertainment purposes only, I don't know anything. If there's one thing I've learned, there is always somebody that knows a ton more about lots of stuff.
Please inform me if I'm full of the smelly stuff that comes out of the south end of a north bound Equine alfalfa processor.
I do suspect a great deal after 51 years playing with recip's. Many, slant six specific. Doesn't mean I'm right.
CJ
PostPosted: Wed Nov 26, 2025 4:26 pm
There is much disagreement over the whole long rod short rod issue. I have seen back to back tests on the same engine that produced almost exactly the same HP and torque numbers when looked at over the whole power band. I used them on my race engine but that was mainly to get a near zero deck and a good piston for higher compression. Actually the guys that built my engine also build world class race engines every day. They have their own dyno and they told me that they actually see more hp with the shorter rods in their engine builds. Of course that is on a V8 and also a circle track engine with specific hp desires at specific times on the track. Such as coming off the turns and heading into the straights. So they are probably looking at a very narrow rpm window where they see this horse power advantage. For us Slant 6 guys I doubt you would ever be able to see a difference either way. Even our standard 225 rod is pretty long when compared to what some V8's are running.
PostPosted: Fri Nov 28, 2025 4:39 pm
I have a long rod motor in my Valiant now. It's faster than the stock rod motor I took out, but it also has a better head and more compression.
Mike used a lot of stock rod motors, but the aluminum rod motor has the 7" rods with a short compression height forged piston I believe of Ford origin. :D
As far as are they worth getting to sell, there's always someone looking for them. You just need to wait for the right guy.
PostPosted: Sun Feb 01, 2026 4:26 pm
What specific measurements should I make before buying a set of 198 rods?
I might be in the market for another set of these, less for the nuances of the torque curve and more for the ability to throw on a cheap set of forged K-car pistons and get a free compression bump.
Escape Velocity Racing
PostPosted: Mon Feb 02, 2026 4:53 am
My thoughts on the 198 rods (I do have a couple of sets). I would not spend much money for them as "cores". They need to be checked, better bolts and resized. By the time you are done, the price is getting close to what a set of Molner or K-1 rods cost. If you plan on running the replacement stock 2,2 pistons you do need the stock 198 rods as the 2.2 flat top pistons are for press fit pins. The aftermarket rods are full float pins (this is why I have the stock 198 rods) The 2.2 "turbo" dished pistons use full float pins, so you can run the aftermarket "good" rods, or the stock 198 rods. The wiseco pistons can be used with floating or press fit rods.
I have a set of TRW flat top 2.2 pistons, and a set of Speed Pro dished "turbo" pistons. Both are forged.
PostPosted: Tue Feb 03, 2026 2:26 pm
I might need to pick your brain on all these piston choices. Is there any benefit to full float pins, aside from ease of assembly?
When I built the engine that's in the turbo racecar, I used dished Silvolite pistons which I think could've been used either way, but I used stock 198 pistons with press-fit pins. I had to buy an extra piston because I wrecked one of them before I got my press set up right...
PostPosted: Wed Feb 04, 2026 2:42 pm
Hi Frank,
Happy to talk about options, advantages and such on the phone sometime. Shoot me a call after Sunday since I'm on travel. Is the turbo LeMons Dart likely to rear its head again??
We ran Event Horizon last weekend at Barber and had fun, although another new VW engine blew up...
PostPosted: Fri Feb 06, 2026 1:51 pm
I heard more than just the car took a beating! I guess there's far worse places to break a bone than at a Lemons race. Glad y'all had a good time and got a trophy out of it!
I intend to have the EVR Turbo Dart ready for MSR in November 2026. It needs a replacement 904 installed, and then a whole bunch of deferred maintenance/odds and ends taken care of. But its current engine is still as healthy as it needs to be.
The engine I'm thinking of building with another set of 198 rods is for the Valiant wagon. We ran it in the Texas Lemons Rally this past December, and it was a hoot. But it was barely maintaining 65 mph on the highway by the time we got home. The bottom end is essentially untouched, so I assume its compression levels have dropped into the yellow-orange range.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
