It is currently Tue Dec 02, 2025 2:38 pm
PostPosted: Mon Dec 01, 2025 6:22 am
Hi Slant Sixers,
Here are a few things I'm giving away, most previously not posted:
1) ~ 1970 Slant 6 oilpan - nice shape, some surface rust, not too dirty - FREE
2) Slant 6 rear sump truck oilpan - nice shape, some surface rust, not too dirty - TAKEN
3) Stock (NEW in box - reground?) camshaft, appears to be 70s grind - TAKEN
4) Early-mid 70s Slant 6 valve cover - nice shape but greasy/dirty - TAKEN
5) Stock mechanical rocker shaft/arm assembly complete - greasy/crusty/dirty but looks good and no rust - FREE
6) A bunch of misc stock pushrods, mechanical and hydraulic - FREE
7) 225 Slant 6 crankshaft - small hub (pre-68), good core - FREE (this will go in the junk soon)
8 ) 2800 RPM high stall converter, cracked pump drive hub so needs a new one welded on by a skilled pro - FREE
Let me know what you want! You pay shipping charges. Thanks for the ad.
PostPosted: Mon Dec 01, 2025 7:21 am
Car Model: 85 Dodge D100
Hey Lou,
I'd be interested in numbers 2,3,&4 if they aren't spoken for. There is no urgency on my end, so if I can pick them up next time we are in the same area that works for me. If you need to get rid of them sooner, I understand. I don't know if we'll see each other over the winter or not? - Maybe I can join Mark C's engine installation party? haha! I assume we aren't having a banquet in person this year again since that's been stopped for a few years now. - Thanks for the generosity!
PostPosted: Mon Dec 01, 2025 7:44 am
Sounds great, Andrew. The oilpan, valve cover, and cam are all yours and I can keep them and hand them off when convenient.
That would be cool to have you here for the Mark C engine swap party! I'm guessing Feb-Apr timeframe. Others are welcome to join too. Always lots of fun...
PostPosted: Mon Dec 01, 2025 8:37 am
Thanks Lou! Let me know when you guys decide. Can't promise anything, but it would be fun to hang out, see you and Mark, and work on stuff.
PostPosted: Tue Dec 02, 2025 1:01 pm
Lou, I might be interested in the converter. I need to get an estimate on replaceing the pump drive.
PS: Is the converter for the early crank or late crank?
PostPosted: Tue Dec 02, 2025 1:36 pm
Sure Charlie! Late crank and trans input. It is an old GER converter, which did not have a great reputation, but this unit worked great for me until the pump drive cracked and it started leaking. Nice for street/strip.
