It is currently Sat Nov 21, 2026 1:13 pm
 Post subject: 65 valiant 100 hop up
PostPosted: Mon Dec 08, 2025 2:43 pm
been awhile since ive been on here....sold my 61 v100 2dr 3spd floor shift a few years ago....im getting the bug again, i just found and bought a 7 1/4 axle with sure grip and 3:90 gears (chicken lip rare and only an hour from me : ) . anyway ive found a 65 v100 170 auto....i was thinking of throwing the sure grip unit in it......but i want it to burn some rubber....is it feasable with the 170 (no turbo,or nos)....just intake / exhaust and trans kit....??? would be running 13's or short 14s street tires.....thanks for any suggestions.....ss
PostPosted: Mon Dec 08, 2025 3:07 pm
Not without a high stall converter. Just remember, what hurts a 7 1/4 rear is "shock loading". Like when a wheel is spinning, and then grabs traction. I ran 7 1/4 rears for years, without problems (even with slicks and/or nitrous), but that was also when you could get repair parts for them.
PostPosted: Tue Dec 09, 2025 2:23 am
Thanks for reply Charlie...i dont plan on doing any "neutral drops"..just foot brake the car...fwiw...the axle i bought also comes with 10 drums :)
PostPosted: Tue Dec 09, 2025 1:11 pm
You might want to check and see what year it is. If I'm not mistaken, the later 7 1/4 shur grips were the "cone" style and only had 2 spider gears. The clutch type had 4 spider gears. I would never consider a 7 1/4 with only 2 spiders. Regardless, parts for any 7 1/4 rear are hard to find, and SG parts even more so. If you're going to beat on the rear forget a 7 1/4.
PostPosted: Wed Dec 10, 2025 10:24 am
Small bolt pattern?
The 7 1/4 in my 76 Dart was Big Bolt with 10 inch drums.
PostPosted: Wed Dec 10, 2025 3:54 pm
sl6 racer....it is from a 66 dart...and i have another sg unit also from a 66 dart....
PostPosted: Wed Dec 10, 2025 3:55 pm
hyper_pak...its out of 66 dart...and is sbp...4"
PostPosted: Fri Dec 12, 2025 5:55 am
Small bolt pattern?
This is the case on the disc brake cars. Front drum cars were small bolt pattern.
PostPosted: Fri Dec 12, 2025 11:21 am
I was told after Jan 1 1976 all A Bodies got BBP and Front Disks.
A1 on the fender tag.
PostPosted: Tue Dec 16, 2025 7:51 am
well...just pulled cover to check things out.....is a sure-grip...buuuuuttttt.....3.23 gears....wah wah wahhhhhh... :roll:
PostPosted: Wed Dec 24, 2025 2:54 pm
We have a 1976 Dart in Dad's back yard. It has small bolt and front drums, not sure of it's build date. But the 1/6/76 changeover makes sense.
