It is currently Thu Oct 22, 2026 6:55 am
PostPosted: Tue Dec 30, 2025 2:14 pm
Car Model: Slant Six M37
Doc's article below mentions stroking via offset grinding the crank and with a 3.5 bore piston and achieving a 240CID slant 6.
https://slantsix.org/articles/stroking/stroking.htm
If such is an option now a days (offset grinding)?
Would these pistons work: https://www.summitracing.com/parts/uem- ... 0#overview
As far as I can tell the compression distance is 0.10 shorter than the stock slant 6 piston
Or does anyone know of a 3.5" bore piston for a stock build?
PostPosted: Tue Dec 30, 2025 5:04 pm
Jase I like your thoughts.
Custom pistons can be made. you will be spending a lot to get this built.
I have a grinder in Dallas and I will be taking a couple cranks early next year.
I will ask him.
PostPosted: Tue Dec 30, 2025 5:44 pm
The amount you can offset grind is small will only gain you a couple cubic inches. The .100 over pistons get you to 238 cu in.
The pistons you list have the wrong size wrist pin.
PostPosted: Tue Dec 30, 2025 8:09 pm
Agreed that the offset grind does not gain much... so maybe it is not worth the effort.. which then probably takes these pistons out of the running.. as they have a slightly short compression height..
And then dealing with finding a bushing that would allow those pistons to be used is also not worth the effort...
I am seeking for options for something that does not require custom pistons and I thought with the above ones with an offset grind, might work....
PostPosted: Wed Dec 31, 2025 4:39 am
Offset grind will work fine with stock comp ht pistons. You can likely still get 0.060"-under or at least 0.050"-under rod bearings from King, which if you have a stock crank in good shape you can get about 0.040" or maybe up to 0.055" extra stroke. 0.040" gives 2.3 extra cubes with a 3.46" bore. My local crank grinder did a mild one like this (0.0075" offset grind for 0.015" extra stroke) for a minimal or no extra charge about 10 yrs ago. We used 0.030" bearings because I had them laying around. You will lose nothing in terms of durability. It will raise your comp height (piston to deck) by 1/2 the gain in stroke. That gets you more compression too with less milling. It's a win-win-win, for most NA buildups.
Now that I've typed this out, I should get more of my cranks offset ground. Time to buy some bearings...
PostPosted: Wed Dec 31, 2025 6:16 am
Yes Lou, you need more projects!
PostPosted: Wed Dec 31, 2025 8:46 am
If someone just could make a custom undersize bearing of say .150" 0r so them you could offset grind a larger amount and pick up some cubic inches and compression even using stock pistons. Anyone know someone at King?? :D
PostPosted: Wed Dec 31, 2025 1:24 pm
Interesting idea, Rick. That would probably work well. The other way would be to use a rod with a smaller journal and offset grind away. Would need to match the pin width, which wouldn't likely work with the forged crank (bearings wider than just about anything), but likely you could find a match with the cast crank.
PostPosted: Thu Jan 01, 2026 3:55 pm
My "smaller journal rod" idea will likely not work either. Almost no engines have a stroke and rod as long as the 225, so finding a small journal with a 6.6-7" rod would be tough.
Here are the 0.060"-under rod bearings for the cast crank engine: KGB-CR6615AM060
0.040"-under for the forged crank engine: KGB-CR614AM040 (put 60 at the end for the 0.060"-under version - not listed)
They are special order and I think King waits to have enough to make a run. I have a set or two of these, but it's been a while since I've ordered them.
I wonder if we called them and asked for a really big undersize (0.100"-0.150") and wanted 20 sets they might do it??
PostPosted: Thu Jan 01, 2026 5:41 pm
Can't hurt to ask?
PostPosted: Fri Jan 02, 2026 6:18 am
The 5.4 Ford modular engine appears to have a 6.657" rod, with a width on the big end at .937. that is too narrow for my forged crank engine? https://www.summitracing.com/parts/esp- ... d#overview
PostPosted: Fri Jan 02, 2026 7:15 am
Interesting! Won't work with forged crank, but might with cast crank. Need to look up big end width.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 19 guests
