It is currently Sat Nov 28, 2026 6:01 pm
Post new topic  Reply to topic  [ 348 posts ]  Go to page Previous 1 … 20 21 22 23 24 Next
 Post subject: Re: Covalt - 85 D100
PostPosted: Fri Jan 02, 2026 5:16 am
Online
Somewhere a lawnmower is missing it's camshaft.
True, but it sure idles nice :D
I'm with ya Dennis. It takes me twice as long to do things since I take coffee and donut breaks every 15 minutes. But that Ok, I'm still moving. :D
Well, at least you are not taking a 45 min. break every 15 min!
:D :D
PostPosted: Fri Jan 02, 2026 6:07 am
At least you people are getting some work done, on the vehicles. I haven't been able to get any time for the "toys". My red 64 Valiant is still in the storage place. I want to set up a 600 sq/ft steel garage, but the wait for the permit is nonsense.
PostPosted: Fri Jan 02, 2026 6:09 am
Now that sounds like my kind of work load. :D :D
PostPosted: Fri Jan 02, 2026 8:23 am
Online
Only if it comes with a Peach Milkshake!
PostPosted: Fri Jan 02, 2026 10:50 am
Correct LMC cam specs. (Lawn Mower Camshaft)
Correct Cam specs- Oregon #2106E - Exhaust lobe on intake and exhaust. 214 duration @.050, .444 lift ,110 LSA
PostPosted: Fri Jan 02, 2026 2:44 pm
I took it for two 15-20 minute drives today and allowed it to warm up and cool down several times. Cold start at @ 26 degrees was great. I want to swap the 02 gauge out of the race car into the truck and do some genuine tuning on the carb. It drives fine but I really don't know where I am mixture wise. Also been slowly adjusting my kick down cable to get it how I like it. Denny will be here shortly and we can put the hood back on. :D :D
PostPosted: Fri Jan 02, 2026 2:56 pm
Online
Nice work. Don't let any of those boys drive it. You always end up with broken stuff when Ryan, Denny, and to a lesset extent, Andrew drive your stuff!
:D :D :D
PostPosted: Fri Jan 02, 2026 6:30 pm
:mrgreen: :mrgreen:
PostPosted: Mon Jan 12, 2026 7:46 am
Drove truck for little over 100 miles. Changed out the oil filter. After I get another couple hundred miles on it I'll do a full oil and filter change. I installed a new factory style throttle cable on the truck. They just work better in my opinion than any I have used that bolt into the firewall. Made a small loop in the cable to get a nice shot at the bracket at the carb. Even with the loop it works silky smooth. Made several small adjustment to the kickdown cable and have it working how I want.
Big debate for me is whether or not to try and make it shift a little less harsh. I have a stage 2 Transgo kit in it and I love it for towing the car and trailer. There is no slippage. But for the truck alone it shifts pretty hard. ( Actually will chirp the tires in the 1-2 shift sometimes)
Next I'll run the valves again and swap in the 02 sensor to zero in the 500 Carter. Runs really good as is, but I'd like to know where I'm at. Not sure if I said it before but power wise it feels almost as good as the backup race engine with a much larger cam but with great idle and drivability. I like it! :D
PostPosted: Mon Jan 12, 2026 9:11 am
Online
Run it down the strip with the same gears as your backup race engine to compare its performance.
I'm glad you're enjoying the progress on your projects.
PostPosted: Mon Jan 12, 2026 10:29 am
Sounds like great results so far, Rick. Tuning and the right combination can often meet or beat "higher performance" stuff, especially in a street driven vehicle.
PostPosted: Mon Jan 12, 2026 11:39 am
At this point I'm not all that worried about speed in the truck. It runs well, feels plenty powerful and sits and idles like a stock engine at 750-800 rpm. I'll probably stick my 3.23 gears back in it and call it a day. :D :D
PostPosted: Fri Jan 23, 2026 9:09 am
Ran the truck for @ another hundred miles and still all is well! Runs great. Started it this morning after sitting all week at 26 degrees and it fired up and purred like a kitten. More to come. :D
PostPosted: Fri Jan 23, 2026 11:41 am
Is this the cam in the truck?
PostPosted: Fri Jan 23, 2026 12:00 pm
Sure is. I really like it. Idles like a stocker and has plenty of power too.
