It is currently Sat Aug 15, 2026 10:17 am
PostPosted: Sat Feb 07, 2026 4:06 am
Thanks, Frank. Glad to hear plans are in the works for the Dart and for your wagon.
I think I may have a set of rebuildable 198 rods. Where will you find the forged 2.2 pistons? Don't think they are easily available anymore, but maybe? Ping me in about a week after I get back from a trip and get settled and can look for the rods. Can talk on phone too after tomorrow...
PostPosted: Sun Feb 08, 2026 7:41 am
I was mistaken; the pistons I used last time are hypereutectic rather than forged. But even these are getting scarce. The only places I've found Silvolite 1291H.STD (standard bore, aka ~0.045" over for a Slant) want $250 for a set of 4.
That being said, assuming this is a legit site, Northern Auto Parts has a bunch of 2.2L piston options for much cheaper. Either 1291H (dished) in overbore sizes, or a couple different flat top varieties in standard bore.
Escape Velocity Racing
PostPosted: Sun Feb 08, 2026 12:17 pm
V6 Chevy pistons can be an option too if your willing to go .102 over? I think my compression was around 10 to 1. Can't remember if you are using this in a turbo set up. That would be too much compression then.
PostPosted: Sun Feb 08, 2026 1:19 pm
This engine would be NA, and if possible use the OCG 346 cam that's been sitting on a shelf in my garage for 6 years.
PostPosted: Mon Feb 09, 2026 5:19 am
The Chev 2.8/3.1 pistons are a possibility for a large overbore, yep. Really, for a non-high-HP NA build, stock replacement 225 pistons (0.060" over) with stock rods are my default... Just don't buy the cheapest crap pistons. Silvolites are still good, I believe.
PostPosted: Mon Feb 09, 2026 8:38 am
I would not worry about 198 rods. I used the 7.000" Molnar rods simply to get a good forged lightweight piston. I have my doubts about the actual power difference between a stock rod length and the long rod option. I have read a lot of different peoples opinions and I just don't think it matters that much from a power standpoint.
PostPosted: Mon Feb 09, 2026 10:31 am
If someone might have a few laying around I still have 3 MP 60 over/6 pistons here new in their boxes. I figured I'd find 3 more somewhere when it came back that my engine would clean up at 0.020 I never put any effort into finding the other 3. I'm a fan of boring an engine over the least amount for which oversized parts are available.
PostPosted: Wed Feb 11, 2026 7:57 pm
Car Model: Mazda RX8 slant six swap
Isn't one big advantage of the long rods is you can use Mohlner rods and 2.2 pistons which are lighter and have thinner rings?
PostPosted: Wed Feb 11, 2026 8:29 pm
Yes but if you are building something that need Molnar rods you are likely going to want a good forged piston like the Weisco's.
PostPosted: Thu Feb 12, 2026 4:22 am
Just an FYI. You cannot use the Molner/K1 rods with a "stock type" 2.2 flat top (non turbo) piston. Those pistons do not have provision for retaining the pin. They require a pressed rod small end. The Molner/K1 rods are only available in floating confiuration. You can use the 2.2 stock type turbo (dished) piston with the Molner/K1 rods as these pistons were full floating from the factory.
