It is currently Thu Oct 22, 2026 4:24 am
PostPosted: Thu Apr 02, 2026 9:08 am
Car Model: 1965 2 Dr Sedan, Wagon, Barracuda and Convertible
I'm getting my engine together. The rebuilt head I have is a 2843169. It didn't have a rocker assembly when I got it. My 2 spare parts motors are later "Peanot" heads. I pulled the rocker assembly and I realized that the oiling bolt is different. the newer one has the stepped smaller thread bolt.
1. Can I just put in the older style bolt and more on?
2. Does anyone have a bolt I could buy/trade
3. Are there any other differences that I'm not seeing?
4. anyone have the proper assembly I could buy/trade?
1965 Valiant 200 /6 2dr Sedan.
1965 Valiant 200 V8 4dr Wagon
1965 Barracuda /6
1965 Valiant Convertible V8
PostPosted: Thu Apr 02, 2026 10:58 pm
I will share this thread. It talks about the differences in the rearmost rocker arm shaft bolt and the interchangeability thereof.
https://www.slantsix.org/forum/viewtopic.php?t=46756
PostPosted: Fri Apr 03, 2026 10:49 am
I did read all of that. Still, the rocker assembly I took off of a later head had the stepped bolt but NOT the 2 different size holes. It also had adjustable rockers that looked like they'd never been adjusted. (What I would expect). It was symmetrical except for the oiling hole. There's a slot inside the rocker that lines up with the hole so it always gets oil. That's the best way to be sure. Lots of interesting combinations came off the MOPAR assembly lines. The only question now is why is there one asymmetrical hold down washer on the newer head.
1965 Barracuda /6
PostPosted: Fri Apr 03, 2026 10:52 am
Pictures of the bolts
https://drive.google.com/open?id=1L9qvI ... p=drive_fs
The head I'm using
https://drive.google.com/open?id=1FI0Zi ... p=drive_fs
1965 Barracuda /6
PostPosted: Fri Apr 03, 2026 11:35 am
If the shaft has the 2 same size holes use a 3/8" bolt and call it a day Mike. :mrgreen:
PostPosted: Fri Apr 03, 2026 12:31 pm
Access denied Mike?
PostPosted: Fri Apr 03, 2026 1:00 pm
Dennis has got it. If end hole is same on both ends of shaft, you are good to use a regular 3/8" bolt.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 18 guests
