It is currently Thu Oct 22, 2026 4:52 am
Post new topic  Reply to topic  [ 90 posts ]  Go to page Previous 1 2 3 4 5 6
PostPosted: Tue Apr 21, 2026 11:38 am
here's a vid
There should be oil all over the place. Everything should have a glossy film of oil on it. There should be oil in that recessed square-headed plug. The spark plug tubes should be oily.
Instead, everything's bone-dry. There's no oil getting to the top end – maybe a clogged passage, maybe the rearmost cam bearing out of position, maybe the rocker shaft installed wrong way round and/or clogged with baked sludge – and whichever valve guides were marginal-to-wonky before ate the replacements for the same valves.
Head's coming off again, for a complete valve job this time. New valves as required, hard exhaust seat inserts, all twelve guides, all twelve valve seats properly ground and lapped, appropriate valve stem seals, springs checked and replaced as necessary, rocker assembly disassembled, thoroughly cleaned and reassembled. All twelve pushrods checked for straightness and replaced as necessary.
Be aware that putting a nice, fresh head atop a tired/worn/high miles engine will often finish off the rings and/or bearings; you can wind up with an oil burner de luxe.
Perhaps some gunk in the intake manifold that's consistently making its way in?
Nope.
PostPosted: Tue Apr 21, 2026 1:26 pm
Some passage is blocked from the block to the head/rocker shaft, probably. Dan has got the possibilities there. I assume you have an oil pressure gauge and the oil pump is making pressure and the main/rod bearings are getting oil?
PostPosted: Tue Apr 21, 2026 5:09 pm
Could he just pull the rearmost rocker arm bolt out and spin the engine over and see if oil is coming up from the cam? It could have spun the rear cam bearing and be blocking the oil passage coming up through.
PostPosted: Tue Apr 21, 2026 6:02 pm
Car Model: '69 Dart Custom
As it appears based on the previous vids, that it's already burning oil (even in the 3 running cylinders). And this isn't a new issue.
It must be bad/stuck rings, eh? Engine has around 75k miles on it; if that means much in conjunction with its sitting time.
I'll have to do another compression/leakdown test to confirm (& adding oil to see if compression improves). I don't remember the last numbers.
Do you think it's worth the head repairs considering the wear/age of the block? Also consider, the oil burning + lack of flow. If it takes any work to the block, I certainly do not have the tools or equipment/shop to arrange that, unfortunately. :(
Here's a theory:
Oil getting past rings; engine burns it; leaves behind nasty buildup; buildup gets stuck behind intake valves and accumulates (here's where I'm skeptical - wouldn't the exhaust valves be most affected?); because of tight guides, the valves get stuck from buildup + when warm, they thermally seize up from metal expansion (indicated by the fact that I could press them a bit after some time, albeit sticky).
This theory kills two birds with one stone. It's either that, or the oil burning and sticky valves are two separate issues.
But the third chirper is still: why is there no oil on top-end...
I don't understand why that'd happen again after flow was restored following the "valve job". I remember now that he did send a video showing nice dribbling out the rockers. When I did the oil change, it wasn't particularly sludgy (but actually, the fuel pump was replaced because of leaky diaphragm)...
I never hooked up an oil gauge, just have the stock idiot light - ironically.
I don't know how to test if the main bearings are getting oil, but I do know that it's burning oil.
I'm so determined to get back on the road because she's just so beautiful.
PostPosted: Tue Apr 21, 2026 6:41 pm
it appears that it's already burning oil (even in the 3 running cylinders). And this isn't a new issue.
Probably.
Cars and their parts deteriorate from prolonged non-use and from prolonged use.
They've got to be done…but given the oil burning, they've got to be done as part of a whole-engine overhaul.
Most of us don't; we have to farm it out.
No, that's not it.
PostPosted: Tue Apr 21, 2026 7:34 pm
Well I got that, but the question is really whether just repairing the head would be enough for occasional light-leisure use (assuming we can restore oil flow without block work) and let it burn oil until perhaps the rings un-stuck themselves after some driving.
As for the head repairs, how much $$$ would you guess it'd land me, all said and done (machining, etc.). Even just a ball-park estimate from your experience
In my case, as much as I'd love to, it'd be too impractical given the money and accessibility constraints.
If not under already, I'd like to at the least stay overwater with this now-medium-sized project.
PostPosted: Wed Apr 22, 2026 5:03 pm
That (rings unsticking) is not very likely, but also not out of the question. How long did this engine sit before it was put back into use, and how many miles has it done since then?
Oof. I'm too many years out of the market to give even a decent guess.
That is a tall order. Old cars eat money! The days when a Dart or Valiant was cheap and easy to fix and keep in parts are pretty much in the past. :(
PostPosted: Wed Apr 22, 2026 8:12 pm
The last head I had done (1year ago) I had the valves and seats ground. Reamed out the guides and installed bronze liners and sized them properly. Lapped all valves and re-assembled with new positive valve seals. $250 total. I did not need any new valves.
PostPosted: Thu Apr 23, 2026 12:39 am
It was sitting around 35 years in a garage on the east coast, up until around a year or two ago when I started working on it. It hasn't been driven more than a couple miles since then due to all the discoveries and the desire to avoid further damage. Plus, it's difficult getting around the block with 3 cylinders - even slant six and all!
I hear ya. I'd be curious how much value my Dart is worth as-is, at the moment vs. if fixed. As seen, the interior is in near-mint condition and I did much work. It's "just" the engine that needs attention at the moment.
That's comforting. What work did you do vs. what did the machinist do?
PostPosted: Thu Apr 23, 2026 3:36 am
He did it all. I did a little bowl porting before I took it to him.
PostPosted: Thu Apr 23, 2026 1:08 pm
Whoof! Okeh, well, you do stand some chance of freeing up the rings. I'd buy enough Kroil to put enough in each cylinder to submerge every piston top once the head's off, then spin the engine (5 seconds on the starter) every day, topping up the Kroil as needed.
Not really directly related, but It will also be a good idea to service the oil pressure relief valve to make sure it's doing its job, as described in these two threads: thread 1, thread 2.
Year, model specifics, number of doors? Odds are its market value doesn't change much one way or the other; best to think of it more in terms of usability and enjoyability to you rather than as an investment.
PostPosted: Thu Apr 23, 2026 1:44 pm
I got quoted around $180 for the work as described (ground valves & seats, liners) by a reputable local machine shop (not including $160 dis/assembly).
Then, I reached out to a highly rated and fairy confident machinist who seemed to call that a total bluff and considered it major work (requiring new seat inserts for the unleaded, as Dan mentioned, etc.) - unwilling to go under $1k.
Initially I was happy to find a great price (closer to what Rick paid), but now I'm second guessing if he knows what he's up against (if it's such a big job after all)...
Anybody care to chime in on what to believe here?
Will absolutely do.
Sounds good. Will check it out.
1969 Dodge Dart Custom 225, 4dr, auto-trans, power steering, no A/C, tan leather interior
The key is, I’m working on someone else’s dime who's doing this purely out of generosity, and so I would like to keep this project within reason (they aren't as car savvy to relate to the costs) - but with an escape plan if the repairs don't work out.
PostPosted: Thu Apr 23, 2026 2:13 pm
This is way, way, way low. Beyond suspiciously low. Given the cost of parts these days, it's even suspiciously low pricing from buddy-who-happens-to-be-good-at-this-stuff-and-has-all-the-tools. Like, unless this is a buddy whose life you saved sometime in the past. Odds are much too great of this $180 and the associated time and effort going ker-flush.
That's more realistic. Consider: In 2011 I bought a top-notch street-engine head from Doug Dutra, which he built for me. $1,200 plus shipping. In today's dollars, that's $1,760.
Not from the factory, it didn't. Vinyl, yes; leather, no. Sounds like a nice car, the kind I like (high-trim 4-door 225/auto). Definitely not to be decided-about with regard to any kind of investment value, definitely in the "what will make it useful, enjoyable, reliable" realm.
Well, the repairs will surely work out, if they're done completely and competently.
PostPosted: Thu Apr 23, 2026 2:52 pm
That being said, I was also quoted $500 from another shop (if I bring the guides), and $400 from a shop with reviews about "Mopar" ingenuity - so I mean...
I was also offered a ready-to-go head with all that was mentioned from a kind lurker here, for less than the cost of good shop work, but I'd have to travel a good 10+ hours from Jersey to pick that up. It's also the later variant with peanut plugs.
Even with my head, they had also mentioned it was worth milling 0.025 to 0.030 off the bottom to compensate with today's head gaskets.
I'm happy we're on the same page here :P
It's worth noting, when the head came off the first time 'round, the two top right and left-most brass manifold bolts snapped off (vid). I'd imagine "competence" includes fixing those, eh? :?
PostPosted: Tue Jul 07, 2026 3:17 pm
Back from overseas and back to the repairs. Great weather for now. 8)
I'd like to address some of the messages now that I'm back with the car.
Looks good. Oil oozes out that rearmost bolt when removed after cranking/running the engine a bit.
As far as the sticking valves (intake 1,5,6), the reason has been discovered. I compressed the springs, removed the retainers, and those valves were so stuck that I had to hammer-slide them out the guides... There was a thick layer of sludge and goop around the seats and along the seat-side of the valve.
Now, I've kindly received a working, built, clean '74 head from the Legendary Lou Dart270 and pray that it will work out as a drop-in replacement. Thank you again! :D
As per Dan,
the cylinders are now sitting in Kroil to try and unstick the rings. I'll leave it overnight (at least) before fitting the new head on - and as I wait for my Remflex manifold gasket to arrive.
But before that, I'd like to be sure that it won't clog up the new head as well. Any insight on what would cause all that goop (and whether or not it takes a lot of time to accumulate)?
(Honestly, from the sheer amount, it makes me think my buddy that did the last valve job didn't actually clean anything since it was barely driven since then).
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 28 guests
