It is currently Sun Oct 18, 2026 12:23 am
PostPosted: Mon Apr 27, 2026 1:34 pm
This truck had a Slant swapped in and a Holley Sniper TBI installed. I'm converting it to a Super Six setup and need help figuring out the trans kickdown. It has a cable installed as shown in the picture (not hooked up yet). It originally attached to the TBI in a hole on the TBI that is below the throttle plate, so pressing down the throttle would pull the kickdown cable. There is no place on the Carter carb to attach it, and I haven't been able to see how I can use the bracket that bolts to the bottom of the exhaust manifold.
I would appreciate any suggestions on how to hook this up. I don't know if the cable is from a Lokar setup. If so, I don't know if I need another part to make it work.
Kickdown cable
Thanks for any suggestions.
Chuck
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Mon Apr 27, 2026 4:14 pm
Chuck-
You will need to do two things. (1) fabricate something to hold the kickdown cable stationary, like the throttle cable is held, and (2) fabricate an adapter that will put the attachment point of the kickdown cable below the throttle shaft so the kickdown cable is pulled out when the throttle cable is pulled in.
I am attaching some pictures of how I did it on my 76 D100 when I put a Carter AFB on a Super Six manifold and used a Lokar kickdown cable. I used the factory two barrel throttle bracket with a cruise control accessory clamp to hold the kickdown cable. I then fabricated a flat plate of steel to bolt to the carb that put the mounting point for the kickdown cable below throttle shaft centerline.
Watch your angles for linkage binding. It took me a few hours of various configurations to come up with the current arrangement. I kept having either too much or too little throttle pressure or binding linkage that held the throttle open.
PostPosted: Tue Apr 28, 2026 8:20 am
Thanks Reed. I was thinking that I would need a plate of some sort that gives me an attachment point below the throttle plate. Doesn't look too bad. I was hoping there was one available that I could buy, but I can probably manage to make one.
PostPosted: Tue Apr 28, 2026 5:39 pm
Maybe THIS or THIS are what you are looking for?
PostPosted: Thu Apr 30, 2026 8:02 am
Reed, I made one like the one in the first link!
Thanks!
PostPosted: Thu Apr 30, 2026 9:43 am
Nice work! My only suggestion is to maybe put a second bolt or screw through the throttle bracket so the lever won't spin if the throttle stud comes loose. Otherwise, great job!
PostPosted: Sat May 02, 2026 1:11 pm
Did that!
Chuck
PostPosted: Sat May 02, 2026 8:36 pm
Excellent!
PostPosted: Sun May 03, 2026 5:43 am
I've got one here (D150, super 6 converted) that I need to get some sort of kickdown control figured out if I can ever get back to working that truck ... Working on my garage lately instead of in it.
Last weekend was new windows ( have 1 more to go) and a new man door
Truck wise I've been working on my 83 d250 which is almost a complete rolling frame again... Got the suspension done, many parts powdercoated even.
I've been wanting to drive the /6 truck again "this year".... It's been sitting long enough
PostPosted: Mon May 11, 2026 11:06 am
You might have to do what I did unless you have the factory Super Six linkage.
PostPosted: Tue May 12, 2026 1:07 pm
I have most of an original super 6 setup ... Most.
Current problems though are too many projects going on at the same time, plus dealing with trying to get the house put back together from a hailstorm 2 months ago (insurance really does suck) and debating on whether to keep my 727 or whether to do the a500 swap in this one. I have the a500 along with the 1960s factory adapter plate and associated spacer, stiffener plates between engine and trans, etc that I'm gonna need to make "that" happen...
Gotta get all the cab seams resealed on this cab, the heater box back in (adding "factory" ac to a truck that originally came without) before I get that far . Need to save this thread
PostPosted: Tue May 12, 2026 4:46 pm
My best advice is to abandon the factory kickdown rod and use a kickdown cable and use the factory cruise control cable clamp swetup to hold the kickdown cable. You can use one for a V-8 on a slant six.
