It is currently Wed Sep 30, 2026 11:02 am
PostPosted: Fri May 15, 2026 8:35 am
Car Model: 62 lancer
Looking for a 4 bbl Hyper- Pak.
I have a single barrel carb. Looking for hyper to hit rod..
PostPosted: Fri May 15, 2026 10:02 am
Unless you are going for a specific look or have specific operating parameters in minf, there are better intakes available for less money than the hyper pak.
PostPosted: Fri May 15, 2026 10:32 am
Are you on face book?
There is a guy has been selling his collection.
Not cheap.
PostPosted: Fri May 15, 2026 11:18 am
I am on Facebook. Prices for original Hyper Pak parts, and even the Clifford reproduction parts, are high.
I am looking for a Clifford reproduction intake because I have a very specific application in mind and intend to modify the intake.
PostPosted: Fri May 15, 2026 5:11 pm
what are you looking to pay Reed?
Just a ballpark in case I find one.
PostPosted: Fri May 15, 2026 5:16 pm
Maybe it's just me but that part of your post makes zero sense
PostPosted: Fri May 15, 2026 8:21 pm
Well, I bought one from Clifford when they still sold them, and I think it was $500 or so.
Knowing what I know now, I probably wouldn't pay much more than $300 for one. I don't care too much about casting flaws since my plan would be to run it as a dry intake.
PostPosted: Sat May 16, 2026 11:22 am
Ok, I am always looking.
PostPosted: Sat May 16, 2026 1:23 pm
It's not just you; the problem isn't on y/our end.
PostPosted: Sat May 16, 2026 11:22 pm
I will take a stab.
"I have a single barrel carb. Looking for hyper to hit rod.."
I believe translates to:
"I have a single barrel carb. Looking for a Hyper Pak to hot rod my car."
If your engine is currently stock and has a single barrel carburetor, jumping straight to a hyper pak is not what you want.
First, get what you have running as good as possible. Thorough tune-up. Check for vacuum leaks. Make sure the vacuum and mechanical advance systems are working corectly in your distributor.
Then start grabbing the low-hanging fruit. Check your timing chain stretch and the accuracy of the timing mark on your vibration damper. Upgrade the diameter of your exhaust to 2 1/2 before the muffler and 2 1/4 after. Free flowing muffler. If you don't have it already, upgrade to some form of electronic ignition. Lash your valves properly. Rebuild the carb. If you have an automatic transmission, make sure the bands are properly adjusted and make sure the transmission kickdown is properly hooked up and adjusted.
Then, and only then, should you start looking to more exotic things like increasing compression, changing the camshaft, and increasing the size of your carburetor. Almost all street driven slant sixes do not need a four barrel carburetor. A two barrel will work just fine.
PostPosted: Wed May 20, 2026 10:03 am
Site Admin
Reed, I always thought that you want a larger exhaust pipe after the muffler because it creates a low pressure area behind the muffler and helps the exhaust flow. Is that not the case?
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Wed May 20, 2026 11:26 am
That is not the case. A larger pipe after the muffler doesn't (can't) create a low-pressure area. All it does is make obnoxious noise by the megaphone effect.
As the exhaust travels through the system, it loses significant heat. As it loses heat, it takes up a lot less volume. A tailpipe smaller than the headpipe is appropriate; it minimizes obnoxious noise and, by maintaining gas velocity, avoids exhaust "pooling" near the car and making you live with the stink when you're stopped in traffic with the windows down.
This recommendation is too big on the headpipe, unnecessarily big on the tailpipe. Putting a 2-1/2" pipe on a stock exhaust manifold without creating a leak is nigh-on impossible, and the 225 doesn't generate nearly enough CFM to come close to benefitting from a 2-1/2" headpipe. All you do is drop the gas velocity, which is not what's wanted. A 2-1/4" headpipe and 2" tailpipe is quite ample; good recipe here (same recipe works well with dual or single exhaust manifold).
PostPosted: Wed May 20, 2026 4:49 pm
The OP has not been back.
There is an Original HP intake on facebook.
$900
PostPosted: Wed May 20, 2026 6:47 pm
Yep, He sent me a private message, 5 days ago, which I replied to, but he hasn't opened it
PostPosted: Thu May 21, 2026 1:38 pm
Site Admin
Thanks Dan. I have the "stink when you're stopped in traffic with the windows down" problem. Actually it always stinks with a window down so at this point i probably have an exhaust leak too. I haven't been driving the car since the insurance tripled. Good old California politics.
