It is currently Thu Oct 22, 2026 12:47 am
 Post subject: Stand Pipe, Yes or No?
PostPosted: Wed Jun 10, 2026 1:29 pm
I haven't run a pump with a stand pipe in a long time.
The 76 Dart Lite had one and I am wondering about using it on the new pump.
Any opinions?
PostPosted: Wed Jun 10, 2026 1:34 pm
Take it off and use an oil filter with the standpipe built in.
I belive SlantSixDan knows the part#'s for such things, or you can use the search function.
I have done both using a standpipe amd also just running the threaded nub in the base of the oil pump.
PostPosted: Thu Jun 11, 2026 5:47 am
I would not be afraid to run it in a normal engine. High performance, high rpm then no. It does cause some restriction.
51806 I think is the Wix number?
PostPosted: Thu Jun 11, 2026 7:57 am
I have 1515 Napa filters.
PostPosted: Thu Jun 11, 2026 9:46 am
Yes that is what I run too. 51806 has the built in standpipe.
PostPosted: Mon Jun 22, 2026 9:10 am
I haven't run one in forever. I don't usually even run a long filter since I had a stockpile of shorties from my Dakota days.
Users browsing this forum: No registered users and 25 guests
