It is currently Fri May 22, 2026 4:12 am
PostPosted: Fri Sep 03, 2004 8:08 am
I'm in the middle of a disc brake conversion on my '74 Scamp and I was planning on reusing my Upper Control Arms but now I'm reading that I need the UCA's from a disc brake car. For some reason I thought the drum and disc UCA's were the same. Is this correct? I have the steering knuckle and sliding caliper adapters from a '74 Scamp.
Thanks
Sweet Emotion
PostPosted: Fri Sep 03, 2004 9:31 am
I'm pretty sure the control arms are the same. The ball joints may not be.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Fri Sep 03, 2004 9:46 am
73-76 A-body UCAs are all the same. Pretty sure BJs are too, but check rockauto.com to verify.
PostPosted: Fri Sep 03, 2004 5:27 pm
The references I have specifically say the 73-76 a body Disc
brake knuckles will bolt up to the ball joints that were stock on the
73-76 a body drum brake cars. You use the UCAs and the
LCAs from any 73-76 abody including the ball joints.
That said there is only one set of ball joint numbers listed for
the 73-76 abody. k 772 upper (both sides), k 781 lower right side,
and k 783 lower left side.
That sure is simple compared with the 72 and earlier As :!:
