It is currently Mon Jun 15, 2026 10:43 am
Post new topic  Reply to topic  [ 120 posts ]  Go to page Previous 14 5 6 7 8
 Post subject: Re: Volare project
PostPosted: Fri Jun 05, 2026 11:34 am
Rick,
I assume there is a logical reason why they are not equally spaced, there has to be, right?!?
'78 Volare 225
'67 Charger 318
PostPosted: Fri Jun 05, 2026 4:39 pm
Probably the same reason Mopars used left handed lug nuts and no one else did :D
PostPosted: Sat Jun 06, 2026 2:24 am
"Extra care in engineering."
Mopar!!!
PostPosted: Sat Jun 06, 2026 2:36 pm
Okay, So all 4 torque converter bolts are in finger tight. Once I got it lined up correctly, all 4 bolts went in easily.
So is it now okay for me to tighten the Bolts down with a wrench?
'78 Volare 225
'67 Charger 318
PostPosted: Sat Jun 06, 2026 3:12 pm
Yes :mrgreen:
PostPosted: Sat Jun 06, 2026 3:54 pm
Yes and I always put lock tight on mine. Especially if they are the small bolts. They do come loose! :D
PostPosted: Sun Jun 07, 2026 2:33 pm
Okay, I removed the bolts and reinstalled them with loctite, per your suggestion, then I tightened them all the way.
Then I reinstalled the thin metal cover on the trans, and then I bolted the engine to trans brace, or bracket.
Babysteps onward…!
'78 Volare 225
'67 Charger 318
PostPosted: Mon Jun 08, 2026 10:11 am
WoooHooooooo!!!! Good job Wes! :mrgreen:
PostPosted: Mon Jun 08, 2026 10:37 am
Just take some spray paint or a paint marker the next time it gets removed and mark one bolt and hole
so you know how it lines up! I usually forget that step myself. Or I wash the paint marks off when cleaning everything up! :D :D
PostPosted: Fri Jun 12, 2026 11:22 am
Okay, so with the original slant six I was using a Weber carb and Lokar kick down cable. The replacement slant six came with a good Carter bbd.
I would like to go back to using the original kickdown rod setup.
Where can I see some pictures of the kickdown installed on a slant six with a Carter bbd?
Thanks!
'78 Volare 225
'67 Charger 318
PostPosted: Fri Jun 12, 2026 12:01 pm
http://www.slantsix.org/articles/supersix/article.htm
Some pictures there
PostPosted: Fri Jun 12, 2026 12:08 pm
Thanks Rick!
'78 Volare 225
'67 Charger 318
PostPosted: Fri Jun 12, 2026 7:51 pm
I found a couple of kIckdown rods in my parts stash, however, they are not complete. They have the main rod, the long one, but the part that hooks up to the carb is missing.
'78 Volare 225
'67 Charger 318
PostPosted: Sun Jun 14, 2026 3:04 pm
I finished installing the radiator today. The bottom rad hose and alternator belt are pretty close, I'm wondering if I misaligned the alternator when I reinstalled it...?
Also, the bracket that holds the throttle cable and kick down cable and mounts to the side of the intake and or exhaust manifold:
I'm gonna check around to see if I stashed it somewhere, but if I can't find it, what is a practical alternative?
Thanks!
'78 Volare 225
'67 Charger 318
PostPosted: Sun Jun 14, 2026 5:26 pm
Online
Yup that belt and the lower hose do run close.... Had that on my truck too.
