It is currently Fri Oct 23, 2026 9:09 pm
PostPosted: Fri Jun 12, 2026 1:23 pm
Car Model: Mazda RX8 slant six swap
I am building a street slant with Molnar 7.005 long rods. Are the Keith Black KB239 pistons still a good choice? They have wrist pin retainers for the full floating pin. My heads are 60cc, so this setup should give me 9.88:1. I'm using a bigger than stock Oregon regrind. It is port injected with a knock sensor. I don't mind using premium fuel.
PostPosted: Sat Jun 13, 2026 6:26 am
Are those pistons cast or forged?
Do they have valve reliefs? (you likely will not need them) Is this an N/A engine or boosted / sprayed with nitrous?
PostPosted: Sat Jun 13, 2026 6:49 am
NA. No nitrous. Cast aluminum. Hypereutectic This my Mazda RX-8 that I have been working on for 4 years. Just a fun project. No racing. Just local parking lot car shows. Dutra Duals, Gill Welding port injection intake, Gill Welding exhaust, Haltech ECU, LS coils. Just something for me to inker with. I have a local engine builder building the engine. Boring to 3.445" 87.5 mm. Money is not a consideration. The KB239 plus the 7.005 rod gives me a zero deck. The modern pustons are lighter to rev a bit higher and have thinner rings for less friction.
PostPosted: Sat Jun 13, 2026 6:58 am
Why not use the Wiseco "forged" pistons Price is about the same when you consider the Wiseco pistons come with the rings, and the KB pistons do not come with rings. Granted with the KB's you will have two spare pistons.
https://www.campbellenterprises.com/sla ... istons.php
PostPosted: Sat Jun 13, 2026 8:49 am
Yes to what Charlie said. Forged pistons cover you for anything in the future too. Especially if money is not an issue.
PostPosted: Sat Jun 13, 2026 10:12 am
Agree with Charrlie and Rick.
PostPosted: Sat Jun 13, 2026 7:17 pm
How bad do the forged pistons rattle when they are cold?
PostPosted: Sun Jun 14, 2026 4:58 am
My opinion. If the engine is bored/honed to match each piston with the proper clearance, you might hear a slight rattle for a minute or two. But most time, with the exhaust noise and/or radio, you will not even hear it.
PostPosted: Sun Jun 14, 2026 5:28 pm
Guys, thanks for the input. I'm going to go with the Keith Black pistons. I'm never going to boost or use nitrous. I want the car to be as quiet as possible. Everything I have been able to read says that cast is fine and Keith Black is a step up. My car will have a knock sensor, so I'm not worried about detonation. The car weighs 3,000 pounds. I don't think it will ever detonate.
PostPosted: Mon Jun 15, 2026 1:48 pm
Should work great. You can make plenty of power with cast pistons.
PostPosted: Tue Jun 16, 2026 8:13 pm
Now if I could just get the machine shop to move.....
PostPosted: Tue Jun 23, 2026 5:24 am
I know the Mohlner rods and modern pistons are lighter than factory. Is there any noticeable increase in RPM because of that?
PostPosted: Tue Jun 23, 2026 6:41 am
Nope.
PostPosted: Tue Jun 23, 2026 2:55 pm
The biggest thing I saw from the 2.2 piston/long rod was the motor loved nitrous.
Running N/A you won't see much difference.
The stock rod/cast piston motor in my Valiant would rev to 7000, but stopped making power around 6200ish so I shifted at 6300.
My long rod motor will also rev to 7000, but gets shifted at 6500 because it has a bigger header on it.
:mrgreen:
PostPosted: Mon Jul 13, 2026 5:37 pm
I guess I will find out what long rods plus KB pistons do. In a few months.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 15 guests
