It is currently Sat Oct 24, 2026 11:07 pm
Post new topic  Reply to topic  [ 145 posts ]  Go to page Previous 1 … 6 7 8 9 10 Next
 Post subject: Re: Volare project
PostPosted: Tue Jun 16, 2026 5:04 am
Ok, thanks Don.
Thanks for the encouragement Dennis!
'78 Volare 225
'67 Charger 318
PostPosted: Fri Jun 26, 2026 10:03 am
So I checked the 4 bolts going into the torque converter, then I installed the starter.
Looking at the throttle cable, its now too long. I was using a Weber 2bbl carb, now I have a Carter bbd carb installed.
What do ya'll recommend for the throttle cable, for a stock super six setup?
Aftermarket, or boneyard scrounging?
This is a mostly stock slant six, but I'm fine with aftermarket or parts pirated from other makes, keeping in mind that I'm on a budget.
Thanks!!!
'78 Volare 225
'67 Charger 318
PostPosted: Fri Jun 26, 2026 11:49 am
Order the factory super six cable from Rock Auto?
PostPosted: Fri Jun 26, 2026 1:03 pm
RA lists 2, both 25.5" long. :D
PostPosted: Fri Jun 26, 2026 1:25 pm
If memory serves, the factory one barrel cable on the F body was longer than the factory two barrel cable. I vaguely remember putting a loop on the one-barrel cable back in the mid to late 90s when I was really into Volares and installed a Super Six on the slant in my old 76 Volare Premiere sedan. There was a time in the 90s when the guys at the local Napa called me "The Volare Kid" because I was in there getting parts for my 78 Volare wagon and my 76 Volare Premiere sedan all the time.
PostPosted: Fri Jun 26, 2026 6:42 pm
Yes I think the 2 barrel is about 4 or 5 inches shorter. The internet says the super six cable is @ 19.5" long and it is @ the same length as the 318 cable. RA lists 19.25' - 20" cables for the 318 so one of them may be the answer.
PostPosted: Sat Jun 27, 2026 3:58 am
Hey Wes
You've been all over a volare for the past while now. I have one here that's as far blown apart as one can be without getting the torch out that needs to go back together. Wanna come over and help do another while yours is fresh in your mind? It's hanging from a homemade rotisserie of sorts with floor pan facing out from the wall.... So it's wide open and easy to get to things.... Think life size revell model kit. I'm again looking for a machine shop to do the engine for my truck since my 3 month wait on a list to get that one done has been extended til late fall if I can't find someone else before then. Maybe if I do an engine for the volare at the same time I can get in somewhere faster if I now have 2 engines for someone to do the machine work on? I have 2 magnum v8s on stands and a couple more laying here to pick from.... Front end is all rebuilt and stacked in the attic, all new ball joints and bushings already put in ntio many years ago....
The only time I've been in Texas (12 or so years ago) I entered the state near the "ark la tex" area. Took I 55 down and branched off from there on my way to Houston. Not far into Texas there was a white 2 door f body that looked solid as could be, sitting next to the barn right off the interstate. I wondered how to get back there from the next exit to get a closer look and at the time to see if it could be bought....
PostPosted: Sun Jun 28, 2026 10:19 am
Hey Don,
Thanks for the invite! If I had the means and I was able to get off work for a time, I might come up there.
I'm sure it would be cooler where you are than it is here in south Texas!
'78 Volare 225
'67 Charger 318
PostPosted: Sat Jul 04, 2026 6:12 pm
Upon closer inspection, it looks like the throttle cable I already have installed may work. I installed the bracket that bolts to the exhaust or intake manifold and has a "clamp" to hold the throttle cable.
I'm still trying to figure out the tranny kickdown. I have a couple of these, but they are not complete.
I installed the EGR blockoff plate with a gasket.
I thought that I may have damaged the radiator when I reinstalled it, but I poured some water into it and it did not leak.
Babysteps, and more babysteps...
Happy 4th of July everybody!
'78 Volare 225
'67 Charger 318
PostPosted: Sun Aug 30, 2026 12:46 pm
Ok, its been a while, and its hot here!
Anyway, I have changed the oil, and put in new spark plugs.
I'm still having trouble figuring out the tranny kickdown, I have it attached at the tranny, but the end that attaches to the carb looks off.
That is, it doesn't look right when I try to attach it to the carb. I think the throttle cable I have will work, but it looks like the tranny kick down needs to attach first.
Also, the oil dipstick tube is being difficult, or I'm doing something wrong.
So, here is what's left:
Tranny kick down
Throttle cable
Oil dipstick tube
Then it needs gas, and a battery.
Batteries have gotten expensive! I'm going to have to wait til I can safely afford one, I don't have a core.
So, getting closer. My biggest obstacle is figuring out the tranny kickdown.
Onward...
Th
'78 Volare 225
'67 Charger 318
PostPosted: Sun Aug 30, 2026 2:31 pm
I my area, the best prices on batteries, is at Rural King. They may not be the best, but I have gotten good service out of them. 3-5 years, and zero problems on replacement if they don't make it to 3 years.
PostPosted: Sun Aug 30, 2026 4:04 pm
No core? What happened to the one that was in the car when it last ran?
Any u pull type places out there? The ones I have dealt with usually test the ones they put out to sell.
Also the interstate battery places around here sell *blems" which usually means only that they've been on the shelf a while. I have had about even "luck" with their blems vs their regular stock. At a much cheaper price
PostPosted: Mon Sep 21, 2026 7:01 pm
Actually, that battery might be laying around somewhere. I can't see myself just throwing away a battery because its dead.
So, this weekend I drained the gas tank in the Volare, then reinstalled the fuel line.
As soon as I can afford to buy a battery, and some gas, I'll see if she fires up.
Getting closer...
'78 Volare 225
'67 Charger 318
PostPosted: Wed Sep 23, 2026 5:01 am
Get a gas can like you use for filling a mower, drop a hose in, hook to fuel pump where you would hook the like from the tank and try it off of that.
PostPosted: Thu Oct 15, 2026 12:49 pm
Ok, today is payday, I did find the old battery so I used that for a core and bought a battery.
I also removed the valve cover and added some oil to the valve train/lifters, and I'll remove the spark plugs to squirt some oil in, per Charrley's suggestions.
I hope my posts on the progress of my Volare project aren't too boring, But they do help me keep going on this project.
And I do appreciate helpful tips and suggestions!
I need to reconnect the positive and negative wires going to the coil, one of them came undone.
And I need to put some gas in it.
I will crank her over before I actually try to start it.
Onward...
'78 Volare 225
'67 Charger 318
