It is currently Sun Nov 15, 2026 6:37 am
PostPosted: Sat Jun 27, 2026 9:15 am
Car Model: Slant Six M37
I bought a good supply of what turns out to be both brass and copper appearing contacts. Is there a functional difference between the two?
PostPosted: Sat Jun 27, 2026 11:41 am
No. Both of them are better than aluminum, but aluminum was perfectly adequate in pretty much all the factory caps. There are things higher up on the list of things to be picky about on caps and rotors.
PostPosted: Sat Jun 27, 2026 1:15 pm
Thanks Dan, that is next on the list, I just used a 3/4 inch bit and hand drill to put 7 holes in an old distributor.. One more to enlarge and it should become the clearance test rig for both slant 6 and LA engines here in the fleet...
